1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [CSS] work without EPICS base ?
To: Pavel Masloff <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 Jan 2012 08:10:24 -0500
Hello Pavel:
As you already noted, you can run CSS without installing EPICS base.
The only quirk is the caRepeater. 99% of users won't notice any difference.
Only those who keep CSS running for a long time, experiencing IOC reboots
or network outages, will find that Channel Access doesn't dependably re-connect
because of the missing CA repeater.
-Kay
From: Pavel Masloff <[email protected]<mailto:[email protected]>>
Date: Tue, 24 Jan 2012 05:57:34 -0500
To: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
caRepeater is not running only if I use pure Java.
If on the contrary I set org.csstudio.platform.libs.epics/use_pure_java=false, then caRepeater launches right after I connect to a PV.
Guys, is it OK to use the pure_java Channel Access??
On Tue, Jan 24, 2012 at 9:47 AM, Pavel Masloff <[email protected]<mailto:[email protected]>> wrote:
Hello to all CSS users!
I am wondering can CSS work without EPICS base?
I reckon the only trouble could be is the carepeater program that searches for the remote IOC's beacons.
Does this mean I should install EPICS base on each computer client in order to use CSS on these clients? If so, can I just copy the EPICS base (for a specific platform) directory and assign the environmental variables (easy solution)? Or I must compile base using make (which is tedious)?
Another thing I've noticed - I have got base installed, but I can't see carepeater.exe in the task manager. Even when I'm running an IOC. I've read somewhere that one should either manually start it or automatically on boot. How would you recommend me to do it (both on linux and windows)?
Thank you very much.
Sincerely,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [CSS] work without EPICS base ? Pavel Masloff
Prev: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Next: Re: errors in vxWorks-6.9/target/h(eader) files when building base 3.14.12.1 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [CSS] work without EPICS base ? Pavel Masloff
Next: errors in vxWorks-6.9/target/h(eader) files when building base 3.14.12.1 Vesna Samardzic-Boban
