1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [CSS] 'Epics' menu in Preferences disappeared!!!
To: "Kasemir, Kay" <[email protected]>
Date: Wed, 25 Jan 2012 00:12:56 +0400
Kay,
I checked in Help, About, Installation Details, Plug-Ins:
org.csstudio.platform.libs.epics.ui - does NOT show up
org.csstudio.ui.preferences - does show up
Plugin.xml looks exactly how you described!
Silly question: how to check the dependencies?
Pavel
On Tue, Jan 24, 2012 at 11:53 PM, Kasemir, Kay <[email protected]> wrote:
Hello Pavel:
Well, the CSS Core/EPICS section of the preference GUI
is provided by the plugin org.csstudio.platform.libs.epics.ui.
So you need to check if it's included in your product.
You describe that it's supposed to be included because
you use some ...core.feature which in turn includes the
 To be 100% sure, check that it's really loaded by the product:
Run the product, see menu Help, About, Installation Details, Plug-Ins.
If that's the case, the next thing to check:
When you look at the plugin.xml of org.csstudio.platform.libs.epics.ui,
you'll see that it tries to provide the "EPICS" settings under
the category="org.csstudio.platform.ui.css.platform".
That preference category is defined by the plugin
org.csstudio.ui.preferences, so now you need to check if it
is indeed included in your product.
As you describe, it should be because of the core.feature that you
use. But check in Help, About, ... if it really is.
If some of these plugins should be included but don't show
up in the running product, check their dependencies.
If all fails, go back to the original product from which you
started, like KEK 3.0.1: When you run that, does it still
include the EPICS preference page, or is something fundamentally
wrong?
-Kay
Date:  Tue, 24 Jan 2012 14:19:31 -0500
To:  Kasemir Kay <[email protected]>
Cc:  "[email protected]" <[email protected]>
Kay!
My CSS product is based upon the KEK 3.0.1. It has 3 features -
org.csstudio.kek.eclipse.feature, org.csstudio.kek.core.feature and
org.csstudio.kek.applications.feature. I have added alarms and archiving
to the applications feature. This epics prefs menu resides in the core
feature - org.csstudio.platform.libs.epics.ui, org.csstudio.ui.preferences
and org.csstudio.ui.help. So these three are in there already, nothing to
change. Still the problem exists.
On Tue, Jan 24, 2012 at 5:07 PM, Kasemir, Kay <[email protected]> wrote:
Hello Pavel:
Sounds like you are finding your way around fine so far!
The "EPICS" preference GUI and some associated online help is provided by
the plugin
org.csstudio.platform.libs.ui, so you need to include that.
To get the 'anchor' points that it uses you may also need to include
org.csstudio.ui.preferences and org.csstudio.ui.help.
-Kay
<[email protected]<mailto:[email protected]>>
Date: Tue, 24 Jan 2012 03:46:02 -0500
To: "[email protected]<mailto:[email protected]>"
Subject: [CSS] 'Epics' menu in Preferences disappeared!!!
Hello,
I was creating my own CSS application in Eclipse RCP, added some features
- Alarms (Alarm Engine, Alarm Config Tool, Annunciator, JMS2RDB), dummy
Auth&authorization and the Archiving system (Archive Engine, Archive
Config Tool). Exported to a complete CSS application. Everything works
absolutely fine, but the 'Epics' menu in Edit->Preferences->CSS core has
disappeared! Of course, I can use the -pluginCustomization ini file, which
i do in any case. Just thought it doesn't look nice since it's not in the
Prefs anymore.
Any suggestions?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Best regards,
Pavel Maslov, MS
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Prev: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
