1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Last chance to save the sequencer's pv layer ?
To: [email protected]
Date: Mon, 30 Jan 2012 02:05:34 +0100
Am Freitag, 27. Januar 2012, 22:46:42 schrieb Matthieu Bec:
> I am looking for a framework to develop state machines, à la SEQ/SNL but
> ... not targeted to epics or channel access.
Which system are you interested in, instead of EPICS/CA?
> The PV API - still present in seq-2.1.4? - seems to go in the right
> direction, but I recall a discussion in 2010 stating it might eventually
> go away.
Does your system fit the PV API framework? It should at least support
subscriptions, i.e. notification messages when a value changes. How are a
variable's alarm status and severity encoded and is this compatible to the way
the PV API defines them?
I may be persuaded to keep the PV layer if it turns out it is of any practical
use. I just don't like to maintain code that nobody uses and thus merely adds
overhead (runtime and maintenance costs). BTW, the sequencer uses only a
subset of the existing API, which I can identify to you, if you are
interested. In any case it would make sense to reduce the API to what the
sequencer actually needs.
Cheers
Ben
Last chance to save the sequencer's pv layer ? Matthieu Bec
Prev: Re: Last chance to save the sequencer's pv layer ? Peter Young
Next: edm1-12-69 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
