1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mcaR7-0
To: "'Szalata, Zenon M.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 1 Feb 2012 18:43:22 +0000
Hi Zen,
This is a known problem with areaDetector R1-7 on older Linux systems.  It is documented in the R1-8 release notes:
  • Support libraries. The static Linux support libraries provided in R1-7 were built on a Fedora Core 9 system (gcc 4.3.0) for 32-bit linux-x86, and on a Fedora Core 14 system (gcc 4.5.1) for 64-bit linux-x86_64. Problems arose when trying to build with these libraries or to run the pre-built binaries on older Linux systems, e.g. those with gcc 4.1.2. These were fixed as follows:
    • The Prosilica libPvAPI.a file had been taken from the AVT gcc 4.3 directory. This was replaced with the one from the gcc 4.1 directory because the 4.3 version requires a newer version of GLIBCXX.
    • The HDF5 library had been built with the default -std=c99. This caused the function isoc99_sscanf() to be called instead of sscanf(), and the former function does not exist on older Linux systems. The HDF library was rebuilt with -std=gnu89 on 32-bit and 64-bit Linux.
    • libGraphicsMagic++.a on 64-bit was invoking std::_List_mode_base functions that do not exist in earlier versions of GLIBCXX. GraphicsMagick was rebuilt on an older Linux system (gcc 4.2.1) for 64-bit Linux.
    • All of the prebuilt 64-bit binaries were recompiled and relinked on an older Linux system (gcc 4.2.1).
R1-8 has not been released yet, but R1-8beta1 has been released, and it fixes this problem.
-----Original Message-----
Sent: Wednesday, February 01, 2012 12:11 PM
To: Mark Rivers; [email protected]
Hi Mark,
I should have remembered that.
So now I am building area detector on RHEL6 64bit Linux and I am getting this link error:
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include      -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/asyn/R4.18/include  -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/calc/R2.9/include  -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/busy/R1.4/include  -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/sscan/R2.7/include  -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/mca/R7.0/include -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/autosave/R4.8/include/os/Linux -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/autosave/R4.8/include -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/include/os/Linux -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/include -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base/include/os/Linux -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base/include       ../simDetectorAppMain.cpp
/usr/bin/g++ -o simDetectorApp -Wl,-Bstatic -L/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/asyn/R4.18/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/autosave/R4.8/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/busy/R1.4/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/calc/R2.9/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/mca/R7.0/lib/linux-x86_64 -L/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/sscan/R2.7/lib/linux-x86_64 -Wl,-rpath,/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/asyn/R4.18/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/autosave/R4.8/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/busy/R1.4/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/calc/R2.9/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/mca/R7.0/lib/linux-x86_64 -Wl,-rpath,/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/sscan/R2.7/lib/linux-x86_64       -m64                simDetectorApp_registerRecordDeviceDriver.o simDetectorAppMain.o   -lsimDetector -lNDPlugin -lADBase -lnetCDF -lcalc -lbusy -lsscan -lautosave -lmca -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lPvAPI -lGraphicsMagick++ -lGraphicsMagickWand -lGraphicsMagick -lNeXus -lhdf5 -lsz -ltiff -ljpeg -lz -Wl,-Bdynamic -lgomp -lX11 -lxml2 -lpng12 -lbz2 -lXext -lfreetype -lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64/libGraphicsMagick++.a(Drawable.o): In function `std::list<Magick::Coordinate, std::allocator<Magick::Coordinate> >::_M_insert(std::_List_iterator<Magick::Coordinate>, Magick::Coordinate const&)':
Drawable.cpp:(.text._ZNSt4listIN6Magick10CoordinateESaIS1_EE9_M_insertESt14_List_iteratorIS1_ERKS1_[std::list<Magick::Coordinate, std::allocator<Magick::Coordinate> >::_M_insert(std::_List_iterator<Magick::Coordinate>, Magick::Coordinate const&)]+0x3a): undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)'
/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64/libGraphicsMagick++.a(Drawable.o): In function `std::list<Magick::VPath, std::allocator<Magick::VPath> >::_M_insert(std::_List_iterator<Magick::VPath>, Magick::VPath const&)':
Drawable.cpp:(.text._ZNSt4listIN6Magick5VPathESaIS1_EE9_M_insertESt14_List_iteratorIS1_ERKS1_[std::list<Magick::VPath, std::allocator<Magick::VPath> >::_M_insert(std::_List_iterator<Magick::VPath>, Magick::VPath const&)]+0x3a): undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)'
/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64/libGraphicsMagick++.a(Drawable.o): In function `std::list<Magick::PathArcArgs, std::allocator<Magick::PathArcArgs> >::_M_insert(std::_List_iterator<Magick::PathArcArgs>, Magick::PathArcArgs const&)':
Drawable.cpp:(.text._ZNSt4listIN6Magick11PathArcArgsESaIS1_EE9_M_insertESt14_List_iteratorIS1_ERKS1_[std::list<Magick::PathArcArgs, std::allocator<Magick::PathArcArgs> >::_M_insert(std::_List_iterator<Magick::PathArcArgs>, Magick::PathArcArgs const&)]+0x3a): undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)'
/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64/libGraphicsMagick++.a(Drawable.o): In function `std::list<Magick::PathCurvetoArgs, std::allocator<Magick::PathCurvetoArgs> >::_M_insert(std::_List_iterator<Magick::PathCurvetoArgs>, Magick::PathCurvetoArgs const&)':
Drawable.cpp:(.text._ZNSt4listIN6Magick15PathCurvetoArgsESaIS1_EE9_M_insertESt14_List_iteratorIS1_ERKS1_[std::list<Magick::PathCurvetoArgs, std::allocator<Magick::PathCurvetoArgs> >::_M_insert(std::_List_iterator<Magick::PathCurvetoArgs>, Magick::PathCurvetoArgs const&)]+0x3a): undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)'
/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/lib/linux-x86_64/libGraphicsMagick++.a(Drawable.o): In function `std::list<Magick::PathQuadraticCurvetoArgs, std::allocator<Magick::PathQuadraticCurvetoArgs> >::_M_insert(std::_List_iterator<Magick::PathQuadraticCurvetoArgs>, Magick::PathQuadraticCurvetoArgs const&)':
Drawable.cpp:(.text._ZNSt4listIN6Magick24PathQuadraticCurvetoArgsESaIS1_EE9_M_insertESt14_List_iteratorIS1_ERKS1_[std::list<Magick::PathQuadraticCurvetoArgs, std::allocator<Magick::PathQuadraticCurvetoArgs> >::_M_insert(std::_List_iterator<Magick::PathQuadraticCurvetoArgs>, Magick::PathQuadraticCurvetoArgs const&)]+0x3a): undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)'
collect2: ld returned 1 exit status
make[3]: *** [simDetectorApp] Error 1
make[3]: Leaving directory `/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/ADApp/simDetectorSrc/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/ADApp/simDetectorSrc'
make[1]: *** [simDetectorSrc.install] Error 2
make[1]: Leaving directory `/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/areaD/R1.7/ADApp'
make: *** [ADApp.install] Error 2
I modified ADApp/Makefile to build only a few components.  Here is my Makefile:
zms@ilc-esb09 $ less Makefile
TOP = ..
include $(TOP)/configure/CONFIG
DIRS += ADSrc
DIRS += netCDFSrc
DIRS += cbfSrc
# prosilicaSupport must be built before pluginSrc or prosilicaSrc because it installs
# header and library files needed by both
DIRS += prosilicaSupport
DIRS += tiffSupport
DIRS += hdf5Support
DIRS += nexusSrc
DIRS += pvcamSupport
DIRS += magickSupport
DIRS += pluginSrc
pluginSrc_DEPEND_DIRS = ADSrc netCDFSrc prosilicaSupport tiffSupport hdf5Support nexusSrc magickSupport
DIRS += simDetectorSrc
simDetectorSrc_DEPEND_DIRS = pluginSrc
DIRS += URLSrc
URLSrc_DEPEND_DIRS = pluginSrc
DIRS += prosilicaSrc
prosilicaSrc_DEPEND_DIRS = pluginSrc
#DIRS += pilatusSrc
#pilatusSrc_DEPEND_DIRS   = pluginSrc cbfSrc
#DIRS += marCCDSrc
#marCCDSrc_DEPEND_DIRS = pluginSrc
#DIRS += mar345Src
#mar345Src_DEPEND_DIRS = pluginSrc
#DIRS += adscSrc
#adscSrc_DEPEND_DIRS = pluginSrc
#DIRS += roperSrc
#roperSrc_DEPEND_DIRS = pluginSrc
#DIRS += firewireWinSrc
#firewireWinSrc_DEPEND_DIRS = pluginSrc
#DIRS += perkinElmerSrc
#perkinElmerSrc_DEPEND_DIRS = pluginSrc
#DIRS += pvcamSrc
#pvcamSrc_DEPEND_DIRS = pluginSrc pvcamSupport
#DIRS += brukerSrc
#brukerSrc_DEPEND_DIRS = pluginSrc
#DIRS += PSLSrc
#PSLSrc_DEPEND_DIRS = pluginSrc
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *db*))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *Db*))
include $(TOP)/configure/RULES_DIRS
> From: Mark Rivers [mailto:[email protected]]
> Sent: Tuesday, January 31, 2012 6:41 PM
> To: Szalata, Zenon M.; [email protected]
> Hi Zen,
> The CanberraSrc directory in mcaApp is failing because you don't have libnet
> and libpcap installed on that system.
> Here are 3 choices.  Any one of them should fix your problem.
> 1) Install libnet and libpcap.  I would only recommend doing this if you want to
> use the Canberra mca modules.
> 2) If you are building using the top-level synApps files then in
> $(SUPPORT)/configure/CONFIG_SITE you will find these lines:
> #Set the following variable to YES if libnet has been installled
> #on the host Linux system for the MCA support module, otherwise,
> #set to NO.
> LINUX_NET_INSTALLED = YES
> export LINUX_NET_INSTALLED
> Change YES to NO and rebuild.
> You could also put that in mca/configure/CONFIG_SITE
> 3) In mcaApp/Makefile comment out the line to build CanberraSrc
> Cheers,
> Mark
> From: Szalata, Zenon M. [[email protected]]
> Sent: Tuesday, January 31, 2012 7:58 PM
> Subject: mcaR7-0
> Hi Mark,
> I am failing miserably to build this module on RHEL6 64bit Linux.
> I get a lot of errors, but some of the first are:
> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
> D_REENTRANT   -g   -Wall     -DUSE_LIBNET -g `libnet-config
>  --defines`   -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux
> /Linux -
> I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/mca/R7.0/include/os/Linu
> x -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/mca/R7.0/include -
>  ../nmc_comm_subs_1.c
> /bin/sh: libnet-config: command not found
> In file included from ../nmc_comm_subs_1.c:70:
> ../nmc_sys_defs.h:52:24: warning: libnet.h: No such file or directory
> ../nmc_sys_defs.h:53:22: warning: pcap.h: No such file or directory
> ../nmc_sys_defs.h:158: error: expected specifier-qualifier-list before 'libnet_t'
> ../nmc_sys_defs.h:188: error: expected specifier-qualifier-list before 'pcap_t'
> ../nmc_sys_defs.h:262: warning: 'struct pcap_pkthdr' declared inside
> parameter list
> ../nmc_sys_defs.h:262: warning: its scope is only this definition or declaration,
> which is probably not what you want
> ../nmc_comm_subs_1.c: In function 'nmc_initialize':
> ../nmc_comm_subs_1.c:170: error: 'PCAP_ERRBUF_SIZE' undeclared (first use
> in this function)
> ../nmc_comm_subs_1.c:170: error: (Each undeclared identifier is reported
> only once
> ../nmc_comm_subs_1.c:170: error: for each function it appears in.)
> ../nmc_comm_subs_1.c:171: error: storage size of 'bpfprog' isn't known
> ../nmc_comm_subs_1.c:172: error: 'bpf_u_int32' undeclared (first use in this
> function)
> ../nmc_comm_subs_1.c:172: error: expected ';' before 'netp'
> ../nmc_comm_subs_1.c:323: error: 'struct nmc_comm_info_struct' has no
> member named 'pcap'
> ../nmc_comm_subs_1.c:323: warning: implicit declaration of function
> 'pcap_open_live'
> ../nmc_comm_subs_1.c:327: error: 'struct nmc_comm_info_struct' has no
> member named 'pcap'
> ../nmc_comm_subs_1.c:330: error: 'pcap_if_t' undeclared (first use in this
> function)
> ../nmc_comm_subs_1.c:330: error: 'alldevs' undeclared (first use in this
> function)
> ../nmc_comm_subs_1.c:331: error: 'd' undeclared (first use in this function)
> Should I try an earlier version of mca?
> Thanks,
> Zen
RE: mcaR7-0 Szalata, Zenon M.
std_R3_1 Szalata, Zenon M.
RE: std_R3_1 Mark Rivers
RE: mcaR7-0 Mark Rivers
Prev: RE: mvme6100 HW issues? Luchini, Kristi L.
Next: asyn reading to waveform records Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: mcaR7-0 Szalata, Zenon M.
Next: RE: mcaR7-0 Szalata, Zenon M.
