Subject: Re: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!!
To: "Zhu, Lixin" <[email protected]>
Date: Mon, 06 Feb 2012 11:30:44 -0600
What is your RTEMS network configuration (the 'SEND failure' and 'Can't send...'
messages indicate that networking is not configured correctly or at all)?
Did you follow the instructions:
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/node18.html#SECTION00514200000000000000
HTH
-- Till
On 02/05/2012 04:16 PM, Zhu, Lixin wrote:
    Hi all,
               I am a new comer for the EPICS (10 days ), and  I am now porting the RTEMS + EPICS to mvme3100 board. I meet the following case ,
  1)      For the  NFS mode,  after i downloading a ICO simple example example.boot, it shows the following infor.
***** Initializing network *****
***** Initializing NFS *****
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
Trying to mount 192.168.10.10:/tftpboot/demo/iocboot/ioctest on /tftpboot/demo/iocboot/ioctest
RPCIO: SEND failure
Unable to contact NFS server - invalid port? (RPC: Unable to send)
nfsMount - mount: Unknown protocol
rtems_bsdnet_get_ntp() Can't send: Host is unreachable
***** Starting EPICS application *****
Can't open /tftpboot/demo/iocboot/ioctest/st.cmd: No such file or directory
192.168.10.9>  pwd
                  I can't mount the nfs server , the  st.cmd can't be called by the example.boot .
    The  server is Debian lenny. I used another Unbuntu linux to mount the nfs server exported directory successfully .
    Any fast method to work aroud the issue ?
2) Since the nfs does't work, i try to turn to the TFTP mode . however,  the error as the following ,
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
6 I2C devices registered
Registering /dev/console as minor 0 (==/dev/ttyS0)
Startup.
***** Initializing TFTP *****
Can't open /TFTP/BOOTP_HOST/epics/169.254.92.2/st.cmd: No such file or directory
169.254.92.2>
            I don't know wether the st.cmd file would be downloaded from the server automatically or not.  It is really no file, only empty directory.
  Anyone who knows about this issue ?
One of the complete log:
Copyright Motorola Inc. 1999-2005, All Rights Reserved
MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM03
Wed Oct 19 17:29:08 MST 2005
MPU-Type             =MPC8540
MPU-Int Clock Speed  =666MHz
MPU-CCB Clock Speed  =333MHz
MPU-DDR Clock Speed  =166MHz
MPU-PCI Clock Speed  =66MHz, PCI, 64-bit
MPU-Int Cache(L2) Enabled, 256KB, L2CTL =A8000300
Reset/Boot Vector    =Flash0
Local Memory Found   =10000000 (&268435456)
User Download Buffer =014D3000:016D2FFF
MVME3100>  tftpGet -c192.168.10.9 -s192.168.10.10 -fdemo/test.boot
Network Loading from: /dev/enet0
Loading File: demo/test.boot
Load Address: 014D3000
Download Buffer Size = 00200000
Client IP Address      = 192.168.10.9
Server IP Address      = 192.168.10.10
Gateway IP Address     = 192.168.10.253
Subnet IP Address Mask = 255.255.255.0
Network File Load in Progress...
Bytes Received =&1676364, Bytes Loaded =&1676364
Bytes/Second   =&1676364, Elapsed Time =1 Second(s)
MVME3100>  netShut
/dev/enet0                 Disabled
/dev/enet1                 Disabled
/dev-----------------------------------------
Welcome to rtems-4.9.3(PowerPC/Generic (no FPU)/mvme3100)
BSP: mvme3100, CVS Release ($Name: rtems-4-9-3 $)
CPU 0x8020 - rev 0x20
Additionnal boot options are H
Initial system stack at 1AB658
Software IRQ stack starts at 1AB750 with size 16384
Going to start PCI buses scanning and initialization
PCI A Status: 09 : 66MHz PCI 64-bit
PCI B Status: B8 :  33MHz PCI 64-bit
         PMC1: ready PMC2: ready  3.3V
PCI C Status: 09 : 66MHz PCI 64-bit
PMC1: empty
PMC2: empty
PMCSpan: empty
Build Date: Thu Apr 14 19:18:32 UTC 2011
Board Type: MVME3100-1152 (S/N E031BAD)
External (=PCI Bus) Clock Freq   :   66666666 Hz
Core Complex Bus (CCB) Clock Freq:  333333330 Hz
CPU Clock Freq:                     133333332 Hz
Ethernet 0                  00:01:AF:31:91:9D
Ethernet 1                  00:01:AF:31:91:9E
Ethernet 2                  00:01:AF:31:91:9F
Number of PCI buses found is : 2
BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1 IRQ_PIN ->  IRQ_LINE
   0:0x00:0    0x1057-0x0008:  0x0006 0x20B0 0x80000000 0x00000000       0 ->    0 (=0x00)
   0:0x11:0    0x10E3-0x0148:  0x0146 0x02B0 0x80100004 0x00000000       1 ->    0 (=0x00)
   0:0x12:0    0x10B5-0x6520:  0x0147 0x02B0 0x00000000 0x00000000       0 ->    0 (=0x00)
   0:0x14:0    0x8086-0x3200:  0x0145 0x02B0 0x00011001 0x00012001       1 ->    2 (=0x02)
   1:0x02:0    0x10B5-0x9030:  0x0142 0x0290 0x80200000 0x00000000       1 ->    6 (=0x06)
Memory:                             268435456 bytes
Cleared PCI errors: pci_stat was 0x20B0
Configuration.work_space_size = 1F4000
OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0xE1040000
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
OpenPIC timer frequency is 41666666 Hz
MSR is 0x00001000, TCR 0x04000000
Exit from bspstart
Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0xC0000000 A32, SUP, D32, SCT
1:    0x00000000 0x00FF0000 0xCF000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0xCFFF0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0xCE000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0:    0xC0000000 0x10000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
Startup.
RPCIO: SEND failure
192.168.10.9>  pwd
  Thank you all.
Kevin Zhu,
FRIB, East Lansing, US
[email protected]
l
RE: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Zhu, Lixin
Prev: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Zhu, Lixin
Next: Charged Particle detectors? Pierrick Hanlet
Next: RE: EPICS IOC NFS mount and TFTP issue for the mvme3100 board, please help, urgent !!! Zhu, Lixin
