Hi All,
Thanks in advance.
How to fill the parameters of the mrmEvrSetupVME(const char *id, int slot, int base, int level, int vector ), especially for the base address and vector number para. ?
I am using the MVME3100 + VME-EVR-230RF / VME-EVG-230 board ,standard VME crate . The EVR & EVG 230 boards, I set them as the slot 2 by setting the jumbers
according to the VME specification datasheet as the following .
Slot GAP* GA4* GA3* GA2* GA1* GA0*
No. Pin Pin Pin Pin Pin Pin
1 Open Open Open Open Open GND
2 Open Open Open Open GND Open
3 GND Open Open Open GND GND
4 Open Open Open GND Open Open
5 GND Open Open GND Open GND
21 Open GND Open GND Open GND
1) I don't quite understand the base address is decided by jumper setting. I am not familiar with the VME protocol, any body tell me , if the slot is 2, then how
to get how to get the base address then ?
2) The EVR or EVR address space will be remapped as a part of the address space of the MVME3100, how to set the last param., the interrupt vector then ?
Does the BSP layer implement a reasonable conversion or .... ? My OS is RTEMS 4-9, bsp is MVME3100 .
How to set the last param ? Thanks~
Catching up time to demo, no time to read carefully the protocols and related datasheet. Appreciate your help :) .
Best regards,
Kevin Zhu
- Re: How to set the parameters of the mrmEvrSetupVME or mrmEvgSetupVME Bjorklund, Eric A
asyn and vxWorks 5.4.2 and earlier Mark Rivers
<2012>
2025
2026
RE: asyn and vxWorks 5.4.2 and earlier Mark Rivers
<2012>
2025
2026
