Subject: Re: Epics driver using BLT or CBLT to read FIFO wanted
To: [email protected]
Date: Wed, 15 Feb 2012 09:21:45 -0600
FWIW. We also have a RTEMS implementation of Andrew's DMA API.
And yes, I'd think integrating this into devLib would be desirable.
Till
On 02/15/2012 08:24 AM, Mark Rivers wrote:
> Hi,
> My SIS3820 driver reads out a FIFO using BLT. Here is the code snippet:
>       if (useDma_ && (count >= MIN_DMA_TRANSFERS)) {
>         asynPrint(pasynUserSelf, ASYN_TRACE_FLOW,
>                   "%s:%s: doing DMA transfer, fifoBuffer=%p, fifo_base=%p, count=%d\n",
>                   driverName, functionName, fifoBuffer_, fifo_base_, count);
>         status = sysDmaFromVme(dmaId_, fifoBuffer_, (int)fifo_base_, VME_AM_EXT_SUP_D64BLT, (count)*sizeof(int), 8);
>         if (status) {
>           asynPrint(pasynUserSelf, ASYN_TRACE_ERROR,
>                     "%s:%s: doing DMA transfer, error calling sysDmaFromVme, status=%d, buff=%p, fifo_base=%p, count=%d\n",
>                     driverName, functionName, status, fifoBuffer_, fifo_base_, count);
> You can get the complete file containing this snippet here:
> https://subversion.xor.aps.anl.gov/synApps/mca/trunk/mcaApp/SISSrc/drvSIS3820.cpp
> This code uses the DMA functions that Andrew Johnson provides in the vxWorks BSPs at the APS.
> I would like to suggest (again) that these functions or something similar should be added to devLib in EPICS base, so that we can all write portable code that uses DMA!
> Cheers,
> Mark
> From: [email protected] [[email protected]] on behalf of Bai Jiaoni [[email protected]]
> Sent: Wednesday, February 15, 2012 7:17 AM
> Subject: Epics driver using BLT or CBLT to read FIFO wanted
> I want to wirte a driver for the hardware, which needs to use record to read the
> data of FIFO(altera FPGA) by BLT or CBLT. Do you know some other dirvers finishing
> the same function?
> Version:Epics 3.13 or 3.14; vxWorks 5.4; VME bus
> I am looking forward to your reply.
RE: Epics driver using BLT or CBLT to read FIFO wanted Mark Rivers
Epics driver using BLT or CBLT to read FIFO wanted Bai Jiaoni
Prev: To users of cothread.catools michael.abbott
Next: Precise time beyond 2038 Di Maio Franck
Prev: RE: Epics driver using BLT or CBLT to read FIFO wanted Mark Rivers
Next: RE: Epics driver using BLT or CBLT to read FIFO wanted Mark Rivers
