1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS X-Y Graph
To: [email protected]
Date: Tue, 21 Feb 2012 18:48:06 -0500
Hello John,
I too have had trouble doing this. I was able to setup a rule to set the buffer size from the NORD field of a waveform record. The result was that, when the size was reduced, the start of the waveform was removed instead of the end. So not very useful.
In the end, as this data was for display only, I "fixed" this by padding the arrays by repeating the last value. This at least produces the correct visual effect.
I would welcome a better solution.
Michael
On 2/21/2012 4:45 PM, John Dobbins wrote:
All,
I am trying to create an X-Y graph for displaying a waveform which may change in length.
A Tech-Talk thread from June 2010
http://www.aps.anl.gov/epics/tech-talk/2010/msg00740.php
suggests to put a PV into "Buffer Size" . However I am trying to do that now (CSS 3.1) and find I can only put an integer into this field, not a PV.
Taking a step back, is there a recommended approach for displaying a waveform which may vary in size. I would like the plot x scale to automatically adjust to the new waveform length.
John Dobbins
Cornell University
Re: CSS X-Y Graph Andrew Johnson
RE: CSS X-Y Graph Chen, Xihui
CSS X-Y Graph John Dobbins
Prev: RE: QT-based tools: Expressions of interest requested Szalata, Zenon M.
Next: Re: CSS X-Y Graph Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS X-Y Graph John Dobbins
