Hi Stephanie,
Thank you for the info!
EDM successfully started-up after running the command:
xset fp+ /usr/share/X11/fonts/75dpi
written in http://www.aps.anl.gov/epics/tech-talk/2008/msg00356.php
CentOS 6 doesn't have a xorg.conf file so I wasn't able to try the
solution written here: http://www.aps.anl.gov/epics/tech-talk/2008/msg00357.php
Thank you again.
Ed
Ed Villasenor <[email protected]>
On Wed, 14 Dec 2011 08:41:59 -0800
"Allison, Stephanie" <[email protected]> wrote:
> Hi Ed,
> This sounds like something discussed in these tech-talk messages:
> We had the font init problem when upgrading to RHEL6 and applied the solution from msg00357.
> Stephanie Allison
> > -----Original Message-----
> > From: [email protected] [mailto:[email protected]] On Behalf
> > Of Ed Villasenor
> > Sent: Tuesday, December 13, 2011 9:30 PM
> > To: John William Sinclair; [email protected]
> > Subject: Re: EDM Installation Error
> > Dear John,
> > I was able to compile edm by changing the const char to char.
> > Unfortunately when I try to start EDM, "Font init failed - abort" error
> > is displayed. Do you know if this error is related to the remFileOpen.cc
> > file that I altered.
> > Regards,
> > Ed
> > On Mon, 05 Dec 2011 09:33:26 -0500
> > John William Sinclair <[email protected]> wrote:
> > > Ed,
> > > The problem is that some versions of g++ require a cast of the form
> > > (const char *)
> > > and others require (char *). Try editing the file and changing the
> > > offending lines from
> > > one of those forms to the other.
> > > John Sinclair
> > > Ed Villasenor wrote:
> > > > Dear All,
> > > > I'm currently installing EDM on a CentOS 6 laptop and came accross the
> > > > same problem described here:
> > > > hxxp://www.aps.anl.gov/epics/tech-talk/2010/msg00157.php
> > > > and hxxp://www.aps.anl.gov/epics/tech-talk/2009/msg01681.php
> > > > Has the solution for this problem been found?
> > > > Additional Info
> > > > - EPICS Base: 3-14-11
> > > > - EDM: 1-11-2i
> > > > - installed
> > > > epics base
> > > > medm
> > > > libpng-1 . 2 . 6rc1-config . tar . gz
> > > > libungif-4 . 1 . 3 . tar . gz
> > > > giflib-4 . 1 . 3 . tar . gz
> > > > zlib-1 . 2 . 5 . tar . gz
> > > > openmotif-2 . 3 . 3-1 . el4.5.i386.rpm
> > > > openmotif-devel-2 . 3 . 3-1 . el4.5.i386.rpm
> > > > I have previously installed EDM on a CentOS 5 Workstation without having
> > > > this problem.
> > > > Kind Regards,
Re: Alarm for noisy readback channel Paul Sichta
Re: QT-based tools: Expressions of interest requested Dirk Zimoch
<2012>
2025
2026
Search for disconnected channels Chris Slominski
<2012>
2025
2026
