Hi Chris,
On 2012-02-23 Chris Slominski wrote:
> I was thinking of a local solution for one process on one host, but I
> will consider your global solution. I'm not sure I want every client
> restarting their searches for disconnected channels.
I would look into trying to fix those IOCs so that they are configured with
the right subnetmask, which (unless they're actually in a different IP subnet)
is all you *should* have to do for their broadcasts to be seen.
Within the context of a single client you could just delete and then re-
connect and subscribe to any one of the disconnected channels, which won't
affect the rest of the program since by definition the channel isn't live. If
there are no disconnected channels then there's obviously no need to do this,
so the issue should be self-regulating.
> > On 23.02.2012 14:18, Chris Slominski wrote:
> >> I want to be able to force my EPICS channel access client to begin a
> >> new search for currently disconnected channels.We have small short
> >> term pc104 iocs come and go and sometimes they are not configured
> >> correctly to broadcast when they have been booted up. A client
> >> listening to the channels won't see a beacon anomaly and begin the
> >> channel search sequence.
> >> I can see a couple of ways to do this.
> >> - Send a network beacon to the CA Repeater.
> >> - Issue a search for some non-existent channel.
> >> Please advise on what is a good way to do this. Example code or
> >> references to EPICS source code are very welcome, as I am neither
> >> familiar with EPICS base software, nor am I an experienced network
> >> programmer. My client software uses EPICS 3.13.10.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Re: Search for disconnected channels Chris Slominski
- Search for disconnected channels Chris Slominski
- Re: Search for disconnected channels Ralph Lange
RE: Best pratices for compiling dbd files for asyn base device support Abadie Lana
RE: Best pratices for compiling dbd files for asyn base device support Mark Rivers
<2012>
2025
2026
<2012>
2025
2026
