1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Search for disconnected channels
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 Feb 2012 18:25:51 +0100
On 23.02.2012 17:10, Chris Slominski wrote:
> I was thinking of a local solution for one process on one host, but I
> will consider your global solution. I'm not sure I want every client
> restarting their searches for disconnected channels.
>   Thanks.
Start the wake-up IOC (using e.g. "echo iocInit | softIoc") on the same
host as your client, with EPICS_CA_ADDR_LIST=127.0.0.1 and
EPICS_CA_AUTO_ADDR_LIST=NO, and you have a one-host solution.
~Ralph
> Ralph Lange wrote:
>> Chris,
>> You need a beacon anomaly that your clients can see, so they rebroadcast
>> their unresolved names.
>> Quick-and-dirty solution:
>> The easiest way to create a beacon anomaly is to start up an IOC. Create
>> an empty soft IOC on a machine on the clients' network (the softIoc
>> executable from base is fine). Set up a cron job that starts the IOC,
>> waits a second, then kills it.
>> Whenever that cron job runs, all clients on the local network will try
>> to resolve their channels.
>> ~Ralph
>> On 23.02.2012 14:18, Chris Slominski wrote:
>>> I want to be able to force my EPICS channel access client to begin a
>>> new search for currently disconnected channels.We have small short
>>> term pc104 iocs come and go and sometimes they are  not configured
>>> correctly to broadcast when they have been booted up. A client
>>> listening to the channels won't see a beacon anomaly and  begin the
>>> channel search sequence.
>>> I can see a couple of ways to do this.
>>> - Send a network beacon to the CA Repeater.
>>> - Issue a search for some non-existent channel.
>>> Please advise on what is a good way to do this. Example code or
>>> references to EPICS source code are very welcome, as I am neither
>>> familiar with EPICS base software, nor am I an experienced network
>>> programmer. My client software uses EPICS 3.13.10.
>>>       Chris
Search for disconnected channels Chris Slominski
Re: Search for disconnected channels Ralph Lange
Re: Search for disconnected channels Chris Slominski
Prev: Re: Search for disconnected channels Chris Slominski
Next: QT-based tools: Expressions of interest requested Mezger Anton-Chr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Search for disconnected channels Ernest L. Williams Jr.
Next: Re: Issues for pvAssing() in seq Benjamin Franksen
