Subject: Re: Setting macro value from commandline
To: <[email protected]>
Date: Mon, 27 Feb 2012 09:31:16 +1100
Sorry, I mean how do you set macro values from the command line for BOY. (I'm new to EPICS and BOY. )
Thanks
Xinyu
On 27/02/2012, at 4:22 AM, Eric Norum wrote:
> When starting a soft IOC you can set the value of iocsh variables from shell environment variables using the epicsEnvSet iocsh command like this:
> epicsEnvSet(KEITHLEY2400_ETHERNET, "$(KEITHLEY2400_ETHERNET=164.54.49.10:4001)")
> So, if you start the IOC like this:
> ./st.cmd
> the iocsh KEITHLEY2400_ETHERNET variable will be set to 164.54.49.10:4001
> but if you start the IOC like this:
> KEITHLEY2400_ETHERNET=192.168.1.2 ./st.cmd
> the  iocsh KEITHLEY2400_ETHERNET variable will be set to 192.168.1.2
> The '=' part to supply a default value can be omitted if you like.
> On Feb 26, 2012, at 2:20 AM, <[email protected]> wrote:
>> Hi,
>> The documentation seems to imply that you can set macro values from the command line. Can anyone tell me how to do it please?
>> Thanks
>> Xinyu WU
>> ASKAP Computing
>> Australia Telescope National Facility
>> CSIRO Astronomy and Space Science
>> phone: +61 2 9372 4727
>> postal: PO Box 76 Epping, NSW. 1710
> Eric Norum
> [email protected]
Xinyu WU
ASKAP Computing
Re: Setting macro value from commandline Kasemir, Kay
Setting macro value from commandline Xinyu.Wu
Re: Setting macro value from commandline Eric Norum
Prev: Re: Setting macro value from commandline Eric Norum
Next: Access PV from JavaScript in BOY Xinyu.Wu
Next: Re: Setting macro value from commandline Kasemir, Kay
