1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Sequencer build rules
To: <[email protected]>
Date: Mon, 27 Feb 2012 12:30:56 +0100
Hi Janet, Andrew, etc
recently there was mention of a build problem when using epics base >=
3.14.12 and user defined rules. A solution was proposed by Bruce Hill:
On Thursday, February 02, 2012, Bruce Hill wrote:
> We ran into this problem recently, trying to build std-2-9
> with seq-2.1.2 and fixed it in the seq configure/RULES_BUILD.
> It looked to me like it resulted from RULES_TOP not being
> defined by base starting w/ R3-14-12.   This kept SNC from
> being defined correctly in seq/configure/RULES_BUILD.
> There's probably other ways to solve this, but we got it to
> work with the attached patch, also shown below.
For better comparison, here is the current (seq-2.1.4) version:
ifdef RULES_TOP
 # EPICS base R3.14.7 and later
 SNC = $(RULES_TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
 # EPICS base R3.14.6 and earlier
 ifndef SNC
  SNC = $(SNCSEQ_HOST_BIN)/snc$(HOSTEXE)
 endif
endif
and this is Bruce's version:
ifdef SNCSEQ
 SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
 ifdef SEQ
  SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
 else
  SNC = $(TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
 endif
endif
Should I include this change in 2.1.5?
Janet, is this how I should do it?
Cheers
Ben
> --- configure/RULES_BUILD (revision 8496)
> +++ configure/RULES_BUILD (revision 8644)
> @@ -33,15 +33,25 @@
>  # snc executable
> -ifdef RULES_TOP
> - # EPICS base R3.14.7 and later
> - SNC = $(RULES_TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
> +#ifdef RULES_TOP
> +# # EPICS base R3.14.7 and later
> +# SNC = $(RULES_TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
> +#else
> +# # EPICS base R3.14.6 and earlier
> +# ifndef SNC
> +#  SNC = $(SNCSEQ_HOST_BIN)/snc$(HOSTEXE)
> +# endif
> +#endif
> +ifdef SNCSEQ
> +SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
>  else
> - # EPICS base R3.14.6 and earlier
> - ifndef SNC
> -  SNC = $(SNCSEQ_HOST_BIN)/snc$(HOSTEXE)
> - endif
> +ifdef SEQ
> +SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
> +else
> +SNC = $(TOP)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
>  endif
> +endif
>  # preserve compatibility to base versions before 3.14.12
>  ifndef ECHO
> On 01/31/2012 05:17 PM, Szalata, Zenon M. wrote:
> > Thanks Mark,
> > I tried the latest version of sequencer (R2.1.4), which did not quite
> > build correctly.  I did not think that mattered.  I now have regressed
> > to an earlier version of sequencer (R2.0.12) and std built without
> > errors.
> > I will look again at the R2.1.4 version of sequencer, see if I can fix
> > that.
> > Thanks again,
> > Zen
> > *From:* Mark Rivers [mailto:[email protected]]
> > *Sent:* Tuesday, January 31, 2012 4:56 PM
> > *To:* Szalata, Zenon M.; [email protected]
> > *Subject:* RE: std_R3_1
> > femto is an SNL program.  Do you have the sequencer in your
> > configure/RELEASE file in std?
> > Mark
> > *From:* [email protected]
> > [mailto:[email protected]] *On Behalf Of *Szalata, Zenon M.
> > *Sent:* Tuesday, January 31, 2012 6:44 PM
> > *To:* [email protected]
> > *Subject:* std_R3_1
> > Building std_R3_1 fails on RHEL6 64bit with this error:
> > /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> > -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE
> > -Dlinux  -D_REENTRANT   -g   -Wall      -m64     -fPIC -MMD -I.
> > -I../O.Common -I. -I.. -I../../../include/os/Linux
> > -I../../../include
> > -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/seq/R2.1.4/include
> > -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/modules/asyn/R4.18/include
> > -I/afs/slac/g/testfac/rhel6/epics/R3.14.12.2/base/include/os/Linux
> > ../pvHistory.c
> > make[3]: *** No rule to make target `femto.o', needed by `libstd.a'.
> > Stop.
> > make[3]: Leaving directory
> > `/afs/slac.stanford.edu/g/testfac/vol1/rhel6/epics/R3.14.12.2/modules/s
> > td/R3.1/stdApp/src/O.linux-x86_64'
> > make[2]: *** [install.linux-x86_64] Error 2
> > make[2]: Leaving directory
> > td/R3.1/stdApp/src'
> > make[1]: *** [src.install] Error 2
> > make[1]: Leaving directory
> > td/R3.1/stdApp'
> > make: *** [stdApp.install] Error 2
> > I did not try building on other architectures, so I don’t know the
> > extent of my problem.
> > What am I missing on this computer?
> > Thanks for any help,
> > Zen
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführerin: Prof. Dr. Anke Rita Kaysser-Pyzalla
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Sequencer build rules Janet Anderson
std_R3_1 Szalata, Zenon M.
RE: std_R3_1 Szalata, Zenon M.
Re: std_R3_1 Bruce Hill
Prev: Access PV from JavaScript in BOY Xinyu.Wu
Next: Re: Setting macro value from commandline Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: std_R3_1 Bruce Hill
Next: Re: Sequencer build rules Janet Anderson
