1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics-php module problem
To: Bertrand Alain <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 28 Feb 2012 11:57:00 -0500
In general, I've been satisfied with the performance of the php_epics module, though I only use it to display small numbers of PVs on a few specialized web pages.
I successfully compiled it on Redhat EL5 recently against PHP 5.3.10 using the following:
CC=gcc
export EPICS=/opt/epics/base-3-14-11
CFLAGS  =  -DUNAME="\"UNAME=$(UNAME)\"" \
   -DLOGINDATE="\"LOGINDATE=$(LOGINDATE)\"" -DUNIX  -I $(EPICS)/include \
   -I $(EPICS)/include/os/Linux  $(SERVER_CFLAGS) -I/usr/local/include -I. -I/opt/php/5.3.10/include/php/ \
   -I/opt/php/5.3.10/include/php/Zend -I/opt/php/5.3.10/include/php/TSRM \
   -I/opt/php/5.3.10/include/php/main -fpic -DCOMPILE_DL=1 -DPNG_SETJMP_NOT_SUPPORTED -DHAVE_PHP_STREAM
LDFLAGS = -static -shared -L/usr/lib -L $(EPICS)/lib/linux-x86 -lCom -lca  -lm -lc
Hope this helps,
-Theo
On 2/28/2012 11:13 AM, Bertrand Alain wrote:
We stopped working on this long time ago due to poor performances we got with PHP. We even actually stopped working with PHP so I must say I have no clue how you compile with PHP 5.
Sincerely,
Alain
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, February 28, 2012 4:24 PM
To: [email protected]
Subject: Epics-php module problem
Is PHP parser/interpreter of adl files (MEDM) ready for use? If so, is it possible to share the source?
While compiling php_epics source it is showing error:
fatal error main/php_config.h : No such file
though I have mentioned the path of php-5 source in Gnumakefile as follows:
   -DLOGINDATE="\"LOGINDATE=$(LOGINDATE)\"" -DUNIX  -I $(EPICS)/base/include \
   -I $(EPICS)/base/include/os/Linux $(SERVER_CFLAGS) -I/usr/local/include -I. -I/home/php-5.x.x -I/home/php-5.x.x/Zend -fpic -DCOMPILE_DL=1 -DPNG_SETJMP_NOT_SUPPORTED -DHAVE_PHP_STREAM
Could you please point out the problem?
with regards,
Tanushyam Bhattacharjee
VECC,Kolkata
Epics-php module problem btanu
RE: Epics-php module problem Bertrand Alain
Prev: Re: QT-based tools: Expressions of interest requested Andrew Johnson
Next: RE: QT-based tools: Expressions of interest requested Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Epics-php module problem Bertrand Alain
Next: Re: Epics-php module problem btanu
