1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CRC issues using Modbus/asyn on 64bit Linux
To: Mark Rivers <[email protected]>, "'Ralph Lange'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 2 Mar 2012 08:53:32 +1100
Hi Mark,
I've had a similar experience with a chain of West 2300 temperature monitors (also serial RTU on RS-485).  In my case the IOC was running on vxWorks, but like Ralph I was seeing persistent modbus CRC errors on the IOC console, although the data itself was good.  I thought it was probably something wrong in my setup but didn't have time to do much investigation.
Emma
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Friday, 2 March 2012 4:47 AM
To: 'Ralph Lange'; EPICS Tech Talk
I should add that the CRC is only used on Modbus serial RTU, not on Modbus TCP or Modbus serial ASCII.
So 2 questions:
1) Has anyone successfully run Modbus/asyn serial RTU on 64bit Linux?
2) Has anyone run the Wave P6100 temperature controller with Modbus/asyn serial RTU on any architecture?
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Thursday, March 01, 2012 11:30 AM
To: EPICS Tech Talk
Subject: CRC issues using Modbus/asyn on 64bit Linux
I am reliably getting CRC errors on the device's answer when reading
more than two parameters (Modbus code 3) through serial RTU on RS-485
from a Wave P6100 temperature controller. The data itself looks good and
reasonable.
One or two word access (Modbus code 1 or 3) seems to work fine.
The IOC runs on 64bit Linux, using Mark Rivers' Modbus on ASYN driver.
(All from synApps 5.5)
Has anyone seen similar behaviour?
Does anyone successfully run Modbus/asyn on 64bit Linux? (To rule out 64
bit issues in the CRC checking part.)
Thanks for any help,
~Ralph
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
RE: CRC issues using Modbus/asyn on 64bit Linux Mark Rivers
CRC issues using Modbus/asyn on 64bit Linux Ralph Lange
Prev: Re: BOY FAQ Benjamin Franksen
Next: Re: BOY FAQ Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CRC issues using Modbus/asyn on 64bit Linux Mark Rivers
Next: RE: CRC issues using Modbus/asyn on 64bit Linux Mark Rivers
