Subject: Re: BOY FAQ
To: "Sinclair, John William" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Mar 2012 16:31:42 -0500
Hello John:
See online help (Menu Help, Help Contents),
look for CSS Applications, Display, BOY, Color and Font.
The help explains the format.
When you install the OPI examples, you also get example
color and font files in there,
then you set your preferences to use those.
Or download the Basic EPICS version which is preconfigured
to use the color and font files from the OPI examples.
Kay
On 3/2/12 16:06 , "Sinclair, John William" <[email protected]> wrote:
>I have downloaded the NSLS CSS product.
>After changing various config parameters, probe and data browser both
>work but BOY does not (pv does not resolve).
>One known problem: I have neither color.def nor font.def and the
>documentation
>complains about an invalid url when I click on the link references. Does
>someone
>have a link to documentation for these files? A simple working example
>would also be
>appreciated. Do I need these files or will the system supply defaults if
>they are missing?
>Thanks,
>John Sinclair
BOY FAQ John William Sinclair
Prev: BOY FAQ John William Sinclair
Next: BOY FAQ John William Sinclair
