Hi Emmanuel,
This looks strange. Are you sure that your link has the correct type,
e.g. INST_IO, not CONSTANT, PV_LINK or CA_LINK or something like this?
Do you check psi->inp.type before you parse the value?
Do 'dbpr "recordname",1' and check the type of the INP link.
Check your .dbd file, too.
Dirk
Emmanuel Mayssat wrote:
Hello,
For a few of my soft records, I used to read the INP field directly with
a command like
[driver code]
myStatus=sscanf(psi->inp.value.instio.string, "@lm=%d df=%[^\n]",
&myLogMark, p_myDateFormat);
[/driver code]
It turns out this method doesn't work correctly anymore.
Indeed the psi->inp.value.instio.string is truncated at the first
'space' char.
In my case, that means, it cannot scanf the 'df= ...'
I also noticed that I now have to include the '@' char, when before I
didn't have to.
That change appeared between 3.14.8 and 3.14.11
What is the correct way to read the INP field now?
Emmanuel
- Re: How to corretly read the INP field? Andrew Johnson
- How to corretly read the INP field? Emmanuel Mayssat
Re: References about EPICS Dirk Zimoch
How do you close a CSS BOY window? Xinyu.Wu
<2012>
2025
2026
<2012>
2025
2026
