Subject: Channel Access
To: [email protected]
Date: Sun, 11 Mar 2012 14:01:41 +0200
Hi all
I am facing problems while after installing EPICS3.14.12.2. in a machine. The EPICS apparently installed successfully without reporting errors. An example application was also made and run using makeBaseApp.pl utility. However the problem is being faced while trying to access the CA variables using channel access. Path to the directory containing caget is added and caget is being called but returning failure in connecting to channel i.e. connectivity to CA variables is not being established.
I need your kind guidance for it.
With Best Regards
Zia
Control Engineer
Synchrotron-light for Experimental Sciences and Applications in the Middle East (SESAME)
P. O. Box 7, Allan 19252, Jordan
Phone: +962-5-3511348 Ext: 239
Cell:     +962-79-5295527
Res:      +962-5-3511463
Re: Channel Access Paul Sichta
Prev: RE: Here is a Message Szalata, Zenon M.
Next: ca_flush_io and threads michael.abbott
Next: Re: Channel Access Paul Sichta
