1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ARM - EPICS performance evaluation
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Mar 2012 15:10:26 +0000
Ø  What is meant by free channel test and pend event test?
The pend event measures the time to call ca_pend_event(1e-9) and the free channel test measures the time to call ca_clear_channel.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Saturday, March 17, 2012 9:58 AM
To: [email protected]
Subject: Re: ARM - EPICS performance evaluation
 I am using the TS7500 (ARM 9) board. By performance evaluation i meant the network and latency performance measurement. I have used the catime tool in EPICs for the client/server network performance (i.e channel access).But the results that i am getting with this board when compared to a linux-x86 system (intel i3 processor) are very poor. I am attaching the two reports generated. Have u performed such measurement for your boards. It would be great if u could suggest something regarding this or how to perform the performance measurements.
ARM 9 Board :
Testing with 10000 channels named VEC:Start
Channel Connect Test
Per Op, 980.5962 uS (   0.0010 MHz ),   0.5221 snd Mbps,   0.2611 rcv Mbps
Search tries per chan - mean = 1.0 std dev = 0.1 min = 1.0 max = 2.0
channel name=VEC:Start, native type=5, native count=1
Pend Event Test
Per Op,   2.9166 uS (   0.3429 MHz )
DBR_FLOAT Test
       ### async put test ###
Per Op, 162.5500 uS (   0.0062 MHz ),   1.1812 snd Mbps,   0.0000 rcv Mbps
       ### async get test ###
Per Op, 193.4481 uS (   0.0052 MHz ),   0.6617 snd Mbps,   0.9925 rcv Mbps
       ### synch get test ###
Per Op, 5874.1800 uS (   0.0002 MHz ),   0.0218 snd Mbps,   0.0327 rcv Mbps
DBR_DOUBLE Test
Per Op, 171.7263 uS (   0.0058 MHz ),   1.1181 snd Mbps,   0.0000 rcv Mbps
Per Op, 188.0780 uS (   0.0053 MHz ),   0.6806 snd Mbps,   1.0209 rcv Mbps
Per Op, 5855.1620 uS (   0.0002 MHz ),   0.0219 snd Mbps,   0.0328 rcv Mbps
DBR_STRING Test
Per Op, 121.9442 uS (   0.0082 MHz ),   3.6738 snd Mbps,   0.0000 rcv Mbps
Per Op, 122.7867 uS (   0.0081 MHz ),   1.0425 snd Mbps,   3.6486 rcv Mbps
Per Op, 10904.0876 uS (   0.0001 MHz ),   0.0117 snd Mbps,   0.0411 rcv Mbps
DBR_INT Test
Per Op, 100.5193 uS (   0.0099 MHz ),   1.9101 snd Mbps,   0.0000 rcv Mbps
Per Op, 124.0433 uS (   0.0081 MHz ),   1.0319 snd Mbps,   1.5478 rcv Mbps
Per Op, 5841.4275 uS (   0.0002 MHz ),   0.0219 snd Mbps,   0.0329 rcv Mbps
Get Latency Test
Get Latency - mean = 6060.9 uS, std dev = 24137.5 uS, min = 2256.0 uS max = 176482.1 uS
Free Channel Test
Per Op,   0.4478 uS (   2.2330 MHz ),   0.0000 snd Mbps,   0.0000 rcv Mbps
x86 system:
Per Op,  12.3947 uS (   0.0807 MHz ),  41.3081 snd Mbps,  20.6540 rcv Mbps
Search tries per chan - mean = 1.1 std dev = 0.2 min = 1.0 max = 2.0
Pend Event Test
Per Op,   2.5694 uS (   0.3892 MHz )
DBR_FLOAT Test
Per Op,   0.8990 uS (   1.1123 MHz ), 213.5624 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.1567 uS (   0.8645 MHz ), 110.6575 snd Mbps, 165.9863 rcv Mbps
Per Op, 223.9892 uS (   0.0045 MHz ),   0.5715 snd Mbps,   0.8572 rcv Mbps
DBR_DOUBLE Test
Per Op,   0.6781 uS (   1.4746 MHz ), 283.1310 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.0460 uS (   0.9560 MHz ), 122.3730 snd Mbps, 183.5595 rcv Mbps
Per Op, 235.0035 uS (   0.0043 MHz ),   0.5447 snd Mbps,   0.8170 rcv Mbps
DBR_STRING Test
Per Op,   0.9966 uS (   1.0034 MHz ), 449.5136 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.0918 uS (   0.9159 MHz ), 117.2383 snd Mbps, 410.3341 rcv Mbps
Per Op, 284.6693 uS (   0.0035 MHz ),   0.4496 snd Mbps,   1.5738 rcv Mbps
DBR_INT Test
Per Op,   0.6753 uS (   1.4809 MHz ), 284.3340 snd Mbps,   0.0000 rcv Mbps
Per Op,   1.0411 uS (   0.9606 MHz ), 122.9506 snd Mbps, 184.4258 rcv Mbps
Per Op, 244.8803 uS (   0.0041 MHz ),   0.5227 snd Mbps,   0.7841 rcv Mbps
Get Latency Test
Get Latency - mean = 214.1 uS, std dev = 51.4 uS, min = 164.8 uS max = 3700.0 uS
Free Channel Test
Per Op,   0.4586 uS (   2.1806 MHz ),   0.0000 snd Mbps,   0.0000 rcv Mbps
Shantonu sahoo.
Date: 03/17/2012 05:44AM
Cc: epics <[email protected]>
Well, I am not sure what you call performance evaluation.
But as far as running epics/seq/etc, that's no problem.
(I used 3.14.11 with minimal patching)
The issue you may be facing is I/O access.
On the ts7370 (ARM9), it takes me 4ms to get a AI reading.
The main issues on this board is
1/ no buffering
2/ you are running a full blown linux OS
For higher througput, I am looking at microcontrollers (arduino megas or more advanced)
Read this to get a flavor of the issues ;)
To have a full blown arm production deployment (as we are strongly considering),
there are practical issues:
1/ management of SD images (SD card)
2/ controlled upgrade/change of SD image
To bypass those issues, we are going in the direction of
beagleboard-xm (full blown linux desktop environment, with epics IOC but no direct critical I/O)
attached to microcontrollers (for critical I/O)
Cost of parts ~ $200
One of my coworkers called this design 'smart chassis': with the spare IO, you can monitor the environment (temp, vibration, etc)
I call it 'epics plug-and-play': You plug your chassis to your network and the epics PV are immediately available.
For maintenance, when the hardware is swapped/changed, the ioc software is changed with it.
For troubleshooting on the bench, engineers/technicians can attach a keyboard and a monitor to a chassis and immediately start working. (Qt works great with embedded systems ;)
We design a lot of our electronics, so by using open hardware solutions, we can *in theory* integrate the ARM+ucontroller directly in our electronics design (maybe at 2nd generation design)
...etc...
In short, they are several advantages to this design which fit *OUR* needs.
Looking forward ARM cpu are becoming more and more powerful, epics/qt is on the way...
You see, the tide is also going that direction...
To: Emmanuel Mayssat <[email protected]>
Sent: Friday, March 16, 2012 9:39 AM
Subject: Re: EPICS performance evaluation
Yes, I am using TS7500 from embeddedarm (ARM9)..
So, have u performed any performance evaluation test for ur arm platform.
Thanking you,
ARM - EPICS performance evaluation ssahoo
Re: ARM - EPICS performance evaluation ssahoo
Prev: Re: catime tool Ralph Lange
Next: Re: ARM - EPICS performance evaluation Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ARM - EPICS performance evaluation ssahoo
Next: ARM - EPICS performance evaluation ssahoo
