Subject: Re: BOY: Macro for workspace directory?
To: Ralph Lange <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 20 Mar 2012 09:56:18 -0400
For sharing things between workspaces, can you used
a common linked folder?
So you'll have something like
CSS/Share
in every workspace.
Then you can put the command directory inside that shared folder
as well.
-Kay
On 3/20/12 07:02 , "Ralph Lange" <[email protected]> wrote:
>Dear BOY experts,
>I am trying to use the "Execute command" action.
>Inside the "Command Directory" property - how do I specify the workspace
>of the current CSS instance? (The command I am executing needs a file
>from inside the workspace.)
>I found "$(user.home)" in the examples, but the "/..." notation that is
>widely used for relative-to-workspace specifications does not seem to
>work here.
>I am sharing things between workspaces even across machines, so absolute
>addressing does not work at all.
>Thanks a lot,
>~Ralph
BOY: Macro for workspace directory? Ralph Lange
Prev: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Pavel Masloff
Next: Re: [ASYN-vxi11] can't connect to Tektronix scope on Fedora 16 Pavel Masloff
Prev: BOY: Macro for workspace directory? Ralph Lange
Next: RE: Macro for workspace directory? Chen, Xihui
