Subject: Re: Problems in using VX2 motor controller
To: sunjl <[email protected]>
Date: Fri, 30 Mar 2012 09:26:35 -0500
Hello Jilei,
You can confirm that the devOMS driver found the
1st Vx2-002 board and not the 2nd by entering the,
dbior "drvOMS"
command at the IOC console.  The response to the
above command should also confirm that the 2nd board
should be at 0xFC10.
Ron
On 3/29/2012 8:43 PM, sunjl wrote:
Dear all,
I have downloaded the motor controller software Ver. R4-8 to do some EPICS training.
Two Vx2-002 motor controller mounted in the VME chest, and I modified the "NoMPF.substitutions" file  as follows:
    file basic_motor.db
    pattern
    {P,     N,  M,      DTYP,         C,  S,  DESC,          EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
    {rls:,  1,  m$(N),  "OMS VME58",  0,  0,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    {rls:,  2,  m$(N),  "OMS VME58",  0,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    {rls:,  3,  m$(N),  "OMS VME58",  1,  0,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    {rls:,  4,  m$(N),  "OMS VME58",  1,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
then, modified the "st.cmd" file as follows:
    # OMS VME driver setup parameters:
    #     (1)cards, (2)axes per card, (3)base address(short, 16-byte boundary),
    #     (4)interrupt vector (0=disable or  64 - 255), (5)interrupt level (1 - 6),
    #     (6)motor task polling rate (min=1Hz,max=60Hz)
    omsSetup(2, 2, 0xFC00, 180, 5, 10)
after gmake, when download the "st.cmd" file, there come some errors:
    filename="../recGbl.c" line number=80
    Illegal field value PV: rls:m3  motor_init_record_com(): card does not exist!
    Illegal field value PV: rls:m4  motor_init_record_com(): card does not exist!
I don't know where the problem is, would you please give me some help, thanks a lot!
2012-03-30
孙纪磊 敬启
中国科学院高htons能物理研究所1号厅201室
北京市918信箱 100049
Sun Jilei
Institute of High Energy Physics, Chinese Academy of Sciences,
Accelerator Center, Room 201, Hall 1,
19B Yuquan Lu, Shijingshan District,
Beijing 100049,
People's Republic of China
Tel.: (+86)-(0)10-88236287
Email:
[email protected]
Problems in using VX2 motor controller sunjl
Prev: RE: What is void* puser in ca_create_channel Hill, Jeffrey O
Next: Re: Re: Problems in using VX2 motor controller sunjl
Prev: Re: Problems in using VX2 motor controller 闫芬
