1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS support for Omega DP470
To: "'Hovanes Egiyan'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Apr 2012 20:26:06 +0000
I've developed support for the Omega DP41.  I don't know how similar the command set is to the DP470.  My support is based on streamDevice, and it is in synApps/ip/ipApp/Db/Omega_DP41.proto and Omega_DP41.db.  Note there is also non-streamDevice support in that same directory, called OmegaDP41.db (without the underscore).
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Hovanes Egiyan
Sent: Monday, April 02, 2012 3:20 PM
To: [email protected]
Subject: EPICS support for Omega DP470
We have a couple  Omega DP470 temperature input modules here that need
remote control and monitoring. Has anyone developed  EPICS support for
this module? If this is the case, I  would appreciate if someone points
me to
where I can get it from.
Thanks in advance,
     Hovanes Egiyan
EPICS support for Omega DP470 Hovanes Egiyan
Prev: EPICS support for Omega DP470 Hovanes Egiyan
Next: RE: asyn w/serial device pushing data Fong, Nia W.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Suggestions for NMR units Angus Gratton
