1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Inspect Samples of CSS shows inconsistent SEVR
To: "Kasemir, Kay" <[email protected]>
Date: Wed, 4 Apr 2012 15:24:51 +0200
Hi Kay,
I believe that the archiver and the data server do a pretty good job.
Misleading are only the Severity and Status values in the Inspect Samples
display in the case of Interpolated data. Maybe there should be a button to
choose the raw data when one really wants to inspect data?
Burkhard
Am 04.04.2012 um 14:39 schrieb Kasemir, Kay:
> Hi:
> The CSS data browser, its sample inspector etc. _show_
> the severity. They don't determine it.
> The "Channel Archiver" source in your example indicates that
> your samples are provided by the Channel Archiver's network data server.
> When that network data server is asked for optimized data,
> it performs interpolation via the "plot binning" described
> on page 14 of http://ics-web.sns.ornl.gov/kasemir/archiver/manual.pdf.
> The values you see are the initial, minimum, maximum, final values within
> each plot bin, though the protocol doesn't really indicate which one is
> which.
> The status/severity is not really handled for those min/max samples.
> The point of the plot binning was to have something that looks 99% the same
> when plotted. It's not meant for introspecting each sample.
> Thanks,
> Kay
> From:  Burkhard Kolb <[email protected]>
> Date:  Wed, 4 Apr 2012 07:51:29 -0400
> To:  "[email protected]" <[email protected]>
> Subject:  Inspect Samples of CSS shows inconsistent SEVR
> Hi,
> when looking at archived data with the CSS trend plot "Inspect Samples"
> tool we
> found some surprises in the archived data:
> It looks like the interpolated samples show the wrong Severity and Status.
> When I export the raw data from the archiver all value/status/severity are
> ok (in this case the LOW limit was set at 20).
> See screen shot of CSS(3.1.0.20120201):
Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
Prev: Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
Next: Re: Inspect Samples of CSS shows inconsistent SEVR Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
