Subject: Re: Proposed support for additional Modbus data types
To: haquin <[email protected]>
Date: Thu, 5 Apr 2012 08:25:10 -0700
On Apr 5, 2012, at 7:19 AM, haquin wrote:
> Hi Mark,
> I started to test the new release R2-4 of your modbus driver,
> 1/ I have a regression problem:
> in case of "intarray_in" when scan mode is I/O Intr:
> Linux IOC crashes with segmentation error message
Could you run this again under GDB and send a stack trace?
> VxWorks IOC doesn't crash but data in the waveform are equal to zero
> On Linux if I start with the scan mode set to none there is no crash.
What happens if you change the mode to I/O Intr after the IOC has started?
> In both cases linux and VxWorks,
> if I change the scanning mode to any periodic scan (with a caput in the SCAN field), I do retreive correct data.
> here is my drvModbusAsynConfigure
> drvModbusAsynConfigure("AR-GT7-PC3:Read_All",    "AR-GT7-PC3", 255,  4 , 0 , 46 , 0 ,  2000 , "InterfaceIocaste")
> here is my waveform:
> record(waveform, "$(EQPT):ReceiveModbusTable") {
>  field(DTYP, "asynInt32ArrayIn")
>  field(FLNK, "$(EQPT):TrigModbusTableProcessing")
>  field(INP, "@asyn($(EQPT):Read_All 0)MODBUS_DATA")
>  field(NELM, "46")
>  field(FTVL, "LONG")
>  field(SCAN, "I/O Intr")
> 2/ I have tested the retreival of float32_LE with ai record, this is ok
> tomorrow I'll test retreival of int32 and also he writting.
> best regards.
Eric Norum
[email protected]
Re: Proposed support for additional Modbus data types haquin
Proposed support for additional Modbus data types Mark Rivers
RE: Proposed support for additional Modbus data types Mark Rivers
Prev: Re: Proposed support for additional Modbus data types haquin
Next: Re: Question about 85XX dual core CPU board for VxWorks/EPICS Andrew Johnson
Next: Re: Proposed support for additional Modbus data types haquin
