1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: does CSS (CAJ?) support CA over an ssh tunnel
To: Peter Milne <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Apr 2012 14:41:31 -0400
Hi:
Two issues.
1) CSS does not use those variables.
You need to check Edit/Preferences/CSS Core/EPICS
and edit them in there, or see
http://sourceforge.net/apps/trac/cs-studio/wiki/HierarchicalPreferences
about setting things like
org.csstudio.platform.libs.epics/auto_addr_list=false
org.csstudio.platform.libs.epics/use_pure_java=true
org.csstudio.platform.libs.epics/addr_list=127.0.0.1:12345
org.csstudio.platform.libs.epics/max_array_bytes=460000
The disadvantage:
Yes, it ignores those env. variables that we've grown
accustomed to.
The advantage:
You can see what it's actually using from Edit/Preferences/...
Compare that to figuring out what StripTool, Probe, EDM, .. are actually
using and which of /etc/bash_profile, ~/.bashrc, ... set it.
2) CSS currently uses CAJ 1.1.7, or a JNI version of JCA that
was build against EPICS base R3.14.11 or older for the Win32 binaries.
I don't think those support CA-over-ssh
-Kay
On 4/9/12 14:15 , "Peter Milne" <[email protected]> wrote:
>Currently using CSS on a remote session over the Net with NX, it's OK,
>but a local session would be better.
>CA tunnelled successfully over ssh:
>(IOC:5064 port forwarded to localhost:10013)
>export EPICS_CA_ADDR_LIST=localhost:10013
>export EPICS_CA_AUTO_ADDR_LIST=no
>export EPICS_CA_NAME_SERVERS=localhost:10013
>camonitor cpsc_011_UPTIME
>cpsc_011_UPTIME 2012-04-09 19:02:06.116235 107056
>cpsc_011_UPTIME 2012-04-09 19:02:07.116355 107057
>But on running css from the same shell session with the same exported
>variables, it's unable to see the PV
>=> Is it possible to view a tunneled PV from CSS?.
>Peter Milne			[email protected]
>D-TACQ Solutions Ltd		www.d-tacq.com
does CSS (CAJ?) support CA over an ssh tunnel Peter Milne
Prev: Re: does CSS (CAJ?) support CA over an ssh tunnel Till Straumann
Next: Re: does CSS (CAJ?) support CA over an ssh tunnel Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
