Hi Ralph,
Is there any manual (tutorial) on how to use it? Thank you.
On Mon, Apr 16, 2012 at 5:50 PM, Ralph Lange <[email protected]> wrote:
Hi all,
procServ V2.6.0 has been released. [1]
The probably most attractive new feature:
* procServ now runs on Windows systems, allowing to remotely access
softIOCs on Windows in the same manner as softIOCs on other systems.
The Windows binary (available for download on SourceForge) has been
built under Cygwin and should run on any recent Windows system. It does
not require a full Cygwin installation - putting the Cygwin1.dll runtime
library into an appropriate place (e.g. the same directory) is sufficient.
Other improvements include:
* Log file lines can be time stamped
* Accepts a signal to reopen log file (to work with the logrotate facility)
* Additional control command to close the telnet connection
* Foreground mode that keeps child process in the starting terminal
* Improvements for cross-builds (autotools and EPICS builds)
Full change log at
http://sourceforge.net/apps/trac/procserv/query?milestone=R+2.6
Thanks to Michael Abbott and Dirk Zimoch, who were helping a lot with
beta testing.
procServ is part of the official distributions of Debian/Ubuntu (as
"procserv") and Fedora/RHEL (as "procServ"). New versions usually take a
few days to get into their respective repositories, but will eventually
be available using the standard package managers.
Enjoy!
~Ralph
[1] procServ is a wrapper application that runs any process (e.g. a
softIOC, a CA Gateway, ...) in the background, allowing telnet access to
its stdin/stdout. It supports logging, child restart (manual or
automatic on crash/exit), blocking characters that are considered
dangerous to the child, and much more.
http://sourceforge.net/projects/procserv/
-- Best regards,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
- Re: procServ softIOC server - V2.6.0 released Ralph Lange
- procServ softIOC server - V2.6.0 released Ralph Lange
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
