1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: log message filter in Asyn
To: [email protected]
Cc: [email protected]
Date: Wed, 18 Apr 2012 15:06:34 -0500
Hi Matt,
On 2012-04-18 [email protected] wrote:
> The problem is is that we already have loads of drivers issuing messages
>  that they shouldn't do, so it would be good to have a solution that
>  doesn't involve modifying these. True, lots of the messages should be only
>  printed once. But there is a case for a driver repeating some kinds of
>  message at some slow rate, to inform the terminal that 'something is still
>  not right'. This gets round the problem of a single message being lost due
>  to some other printout going on.
Is the fundamental issue then that its hard to use the IOC console to debug or
fix problems because of the volume of error messages you're getting?  That's
what 'eltc 0' is for, it stops all the background error messages coming from
Asyn perfectly for me.
Now if you can't use that because the IOC doesn't also send its errors to an
iocLogServer and using 'eltc 0' would cause them to be lost completely, you
could create an errlog listener which buffers (and possibly de-duplicates if
you wish) the errlog messages into RAM.  You would provide your own command
which turns on the buffer and calls eltc(0), and another one which prints out
the stored messages, stops buffering and calls eltc(1) for when you're
finished debugging.  See errlog.h and chapter 10 of the AppDevGuide for more
details of the errlogAddListener() API.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: log message filter in Asyn Mark Rivers
log message filter in Asyn matthew.pearson
Re: log message filter in Asyn Benjamin Franksen
RE: log message filter in Asyn matthew.pearson
Prev: RE: log message filter in Asyn matthew.pearson
Next: RE: log message filter in Asyn Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
