This release corrects a number of bugs including build issues with
vxWorks. It also adds several minor features.
http://epics.sourceforge.net/mrfioc2/
Bug fixes
* Fix several vxWorks build issues
* Correct initial mapping for EVR output channels to Force Low
(aka. Off)
* Fix readback of EVG sequencer run mode.
* Limit number of soft event send retries
* More check for EVG and EVR during initialization. Should now
catch old firmware versions and CSR address mapping problems.
* Delay enabling VME interrupts for EVG until later during IOC startup.
* Fix autosave/restore of CML output bit patterns.
* Remove rear transition module definitions from default EVG db
template
* Fix locking issue in data buffer tx/rx. A deadlock would occur
when trying to send a buffer with the link mode set to dbus only.
Features
* Added evralias.db to facilitate creation of PV name aliases for
EVR delay generator channels.
* Always reset all EVG multiplexed counters when a divider value is
changed.
* Add counter to track number of times each EVG sequencer is run.
* Add mrmEvrForward() shell function to configure EVR event
forwarding to downstream EVRs.
Control Engineer Job in SESAME ibrahim.saleh
Re: RTEMS driver for SIS3820 scaler Kate Feng
<2012>
2025
2026
6259 epics driver help ibadillo
<2012>
2025
2026
