1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [ASYN] connect/disconnect
To: Pavel Masloff <[email protected]>
Date: Sat, 28 Apr 2012 13:55:37 +0000
Is this a local serial port, or on a terminal server?  What operating system?
You should be able to do disconnect from the device in asyn with pasynCommon->disconnect(), and that should free up the serial port for other applications.  You may not even need to do this if the OS lets more than 1 application use the serial port at once.
Sent: Saturday, April 28, 2012 7:12 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Subject: [ASYN] connect/disconnect
Hello Mark, gentlemen
I am connecting to a device over RS232 using ASYN.
Can I disconnect from the device without stopping the IOC and connect to the device via Python for example?
I want to save the waveforms from an oscilloscope by other means than EPICS (Python). Then, when I have saved them, I want to use the device again by means of EPICS.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: [ASYN] connect/disconnect Pavel Masloff
Prev: RE: [Scopes] BMP image record?? Mark Rivers
Next: Re: [ASYN] connect/disconnect Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [ASYN] connect/disconnect Pavel Masloff
