Subject: AreaDetector Roper or PVCam IOC link problem
To: <[email protected]>
Date: Mon, 30 Apr 2012 17:53:01 +0000
Hello All,
I am trying to build an IOC on windows 32 to drive a princeton instruments CCD via AreaDetector.  The exisiting roper or pvcam drivers should both be able to control this device.
I am getting the same link issue when I try to build an IOC with either of these drivers. I am getting unresolved externals in either roper.lib or pvcam.lib. The externals appear to be asynportdriver methods but are named a little differently to the actual functions in asynportdriver. I cannot discover where these dependencies are coming from despite investigating the code for both lib files.
The symbols in question are:
    getUInt32DigitalInterrupt@asynPortDriver
    clearUInt32DigitalInterrupt@asynPortDriver
    setUInt32DigitalInterrupt@asynPortDriver
They do not seem to appear in any versions of asyn that I looked in. (I am trying to link against asyn 4-14)
Detailed output from the link is pasted below.
Any pointers appreciated.
   giles...
link -nologo  /LTCG /incremental:no /opt:ref /release               -out:BL16I-EA-IOC-11.exe       BL16I-EA-IOC-11_regis
terRecordDeviceDriver.obj BL16I-EA-IOC-11Main.obj     W:/prod/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/dxp.lib  W:/pro
d/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/handel.lib  W:/prod/R3.14.11/support/seq/2-0-12dls1/lib/win32-x86/seq.lib
W:/prod/R3.14.11/support/seq/2-0-12dls1/lib/win32-x86/pv.lib  C:/epics/support/areaDetector/lib/win32-x86/roper.lib  W:/
epics/R3.14.11/base/lib/win32-x86/recIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/softDevIoc.lib  W:/epics/R3.14.11/bas
e/lib/win32-x86/miscIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/rsrvIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbto
olsIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/asIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbIoc.lib  W:/epics/R3.
14.11/base/lib/win32-x86/registryIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbStaticIoc.lib  W:/epics/R3.14.11/base/l
ib/win32-x86/ca.lib  W:/epics/R3.14.11/base/lib/win32-x86/Com.lib  W:/prod/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/DL
PORTIO.lib  W:/prod/R3.14.11/support/dxp/3-0dls3/lib/win32-x86/PlxApi.lib  C:/epics/support/areaDetector/lib/win32-x86/N
DPlugin.lib  C:/epics/support/areaDetector/lib/win32-x86/ADBase.lib  C:/epics/support/areaDetector/lib/win32-x86/netCDF.
lib  W:/prod/R3.14.11/support/calc/2-8dls2/lib/win32-x86/calc.lib  W:/prod/R3.14.11/support/busy/1-3dls3/lib/win32-x86/b
usy.lib  W:/prod/R3.14.11/support/sscan/2-6-6dls1/lib/win32-x86/sscan.lib  W:/prod/R3.14.11/support/autosave/4-6dls2/lib
/win32-x86/autosave.lib  W:/prod/R3.14.11/support/mca/6-12-4dls1/lib/win32-x86/mca.lib  W:/prod/R3.14.11/support/asyn/4-
14/lib/win32-x86/asyn.lib  W:/epics/R3.14.11/base/lib/win32-x86/recIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/softDev
Ioc.lib  W:/epics/R3.14.11/base/lib/win32-x86/miscIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/rsrvIoc.lib  W:/epics/R3
.14.11/base/lib/win32-x86/dbtoolsIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/asIoc.lib  W:/epics/R3.14.11/base/lib/win
32-x86/dbIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/registryIoc.lib  W:/epics/R3.14.11/base/lib/win32-x86/dbStaticIoc
.lib  W:/epics/R3.14.11/base/lib/win32-x86/ca.lib  W:/epics/R3.14.11/base/lib/win32-x86/Com.lib  C:/epics/support/areaDe
tector/lib/win32-x86/PvAPI.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_Magick++_.lib  C:/epics/support/area
Detector/lib/win32-x86/CORE_RL_wand_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_magick_.lib  C:/epics/supp
ort/areaDetector/lib/win32-x86/CORE_RL_coders_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_filters_.lib  C:
/epics/support/areaDetector/lib/win32-x86/CORE_RL_bzlib_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_jbig_.
lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_jp2_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_j
peg_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_lcms_.lib  C:/epics/support/areaDetector/lib/win32-x86/COR
E_RL_libxml_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_png_.lib  C:/epics/support/areaDetector/lib/win32-
x86/CORE_RL_tiff_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_ttf_.lib  C:/epics/support/areaDetector/lib/w
in32-x86/CORE_RL_wmf_.lib  C:/epics/support/areaDetector/lib/win32-x86/CORE_RL_xlib_.lib  C:/epics/support/areaDetector/
lib/win32-x86/CORE_RL_zlib_.lib  C:/epics/support/areaDetector/lib/win32-x86/NeXus.lib  C:/epics/support/areaDetector/li
b/win32-x86/hdf5dll.lib  C:/epics/support/areaDetector/lib/win32-x86/szip.lib  C:/epics/support/areaDetector/lib/win32-x
86/zlib1.lib setupapi.lib ole32.lib oleaut32.lib Gdi32.lib Oleaut32.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib
winmm.lib
nafxcw.lib(afxmem.obj) : error LNK2005: "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) already defined in LI
BCMT.lib(new.obj)
nafxcw.lib(afxmem.obj) : error LNK2005: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCMT.
lib(delete.obj)
nafxcw.lib(afxmem.obj) : error LNK2005: "void * __cdecl operator new[](unsigned int)" (??_U@YAPAXI@Z) already defined in
 LIBCMT.lib(new2.obj)
nafxcw.lib(afxmem.obj) : error LNK2005: "void __cdecl operator delete[](void *)" (??_V@YAXPAX@Z) already defined in LIBC
MT.lib(delete2.obj)
nafxcw.lib(afxmem.obj) : warning LNK4006: "void * __cdecl operator new(unsigned int)" (??2@YAPAXI@Z) already defined in
LIBCMT.lib(new.obj); second definition ignored
nafxcw.lib(afxmem.obj) : warning LNK4006: "void __cdecl operator delete(void *)" (??3@YAXPAX@Z) already defined in LIBCM
T.lib(delete.obj); second definition ignored
nafxcw.lib(afxmem.obj) : warning LNK4006: "void * __cdecl operator new[](unsigned int)" (??_U@YAPAXI@Z) already defined
in LIBCMT.lib(new2.obj); second definition ignored
nafxcw.lib(afxmem.obj) : warning LNK4006: "void __cdecl operator delete[](void *)" (??_V@YAXPAX@Z) already defined in LI
BCMT.lib(delete2.obj); second definition ignored
   Creating library BL16I-EA-IOC-11.lib and object BL16I-EA-IOC-11.exp
roper.lib(roper.obj) : error LNK2001: unresolved external symbol "public: virtual enum asynStatus __thiscall asynPortDri
ver::getUInt32DigitalInterrupt(int,unsigned int *,enum interruptReason)" (?getUInt32DigitalInterrupt@asynPortDriver@@UAE
?AW4asynStatus@@HPAIW4interruptReason@@@Z)
ver::getUInt32DigitalInterrupt(int,int,unsigned int *,enum interruptReason)" (?getUInt32DigitalInterrupt@asynPortDriver@
@UAE?AW4asynStatus@@HHPAIW4interruptReason@@@Z)
ver::clearUInt32DigitalInterrupt(int,unsigned int)" (?clearUInt32DigitalInterrupt@asynPortDriver@@UAE?AW4asynStatus@@HI@
Z)
ver::clearUInt32DigitalInterrupt(int,int,unsigned int)" (?clearUInt32DigitalInterrupt@asynPortDriver@@UAE?AW4asynStatus@
@HHI@Z)
ver::setUInt32DigitalInterrupt(int,unsigned int,enum interruptReason)" (?setUInt32DigitalInterrupt@asynPortDriver@@UAE?A
W4asynStatus@@HIW4interruptReason@@@Z)
ver::setUInt32DigitalInterrupt(int,int,unsigned int,enum interruptReason)" (?setUInt32DigitalInterrupt@asynPortDriver@@U
AE?AW4asynStatus@@HHIW4interruptReason@@@Z)
BL16I-EA-IOC-11.exe : fatal error LNK1120: 6 unresolved externals
RE: AreaDetector Roper or PVCam IOC link problem Mark Rivers
Prev: Re: [Scopes] BMP image record?? Matt Newville
Next: RE: AreaDetector Roper or PVCam IOC link problem Mark Rivers
Prev: 9th NOBUGS conference announcement - registration open Tobias.Richter
