Subject: CA_PROTO_READ_NOTIFY Response
To: <[email protected]>
Date: Wed, 2 May 2012 11:12:42 +0000
All,
According to the Channel Access protocol specification from the Cosylab website, parameter 1 of the header of a CA_PROTO_READ_NOTIFY response contains the channel SID (the same as the request header received).
Is this correct?  Monitoring network traffic from a 3.14.12 win32-x86 soft IOC, this value always appears to a fixed value of 1, no matter what the serverID, or clientID of the channel.  Returning anything other than 1 also appears to break correct functioning of a caget.
Graham
Header
Field
Value
Description
Command
15
Command identifier for CA_PROTO_READ_NOTIFY.
Payload size
Size of payload
Size of DBR formatted data in payload.
Data type
DBR type
Payload format.
Data count
>= 0
Payload element count.
SID
Same as request
SID of the channel.
IOID
Same as request
IOID of this operation.
Scanned by iCritical.
Re: CA_PROTO_READ_NOTIFY Response Mark Davis
RE: CA_PROTO_READ_NOTIFY Response Hill, Jeffrey O
Prev: Scopes / Transient Recorders for Misc Signal Acquisition Ralph Lange
Next: Re: CA_PROTO_READ_NOTIFY Response Mark Davis
