1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem installing CA for QT
To: manta santosh aditya santosh_aditya <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 May 2012 09:20:46 +1000
Hi Santosh
Have you defined the environment variable QCAFRAMEWORK?
In your case it would need to be
export QCAFRAMEWORK=/home/santosh/Downloads/epicsqt/ca_framework
If that doesn’t work, perhaps send me a copy the entire build output as well as the output from the ‘env’ command.
Regards
Andrew
From: [email protected] [mailto:[email protected]] On Behalf Of manta santosh aditya santosh_aditya
Sent: Friday, 4 May 2012 11:45 PM
To: [email protected]
Subject: Problem installing CA for QT
I download software for Channel Access for QT and extracted the tar file. when building the pro file i am getting the following error:
/myepics/base/include -Irelease -I. -o release/QCaSpinBoxPluginManager.o src/QCaSpinBoxPluginManager.cpp
src/QCaSpinBoxPluginManager.cpp:32:37: fatal error: QCaSpinBoxPluginManager.h: No such file or directory
compilation terminated.
make[2]: *** [release/QCaSpinBoxPluginManager.o] Error 1
make[2]: Leaving directory `/home/santosh/Downloads/epicsqt/ca_framework/plugins'
make[1]: *** [release] Error 2
make[1]: Leaving directory `/home/santosh/Downloads/epicsqt/ca_framework/plugins'
make: *** [sub-ca_framework-plugins-make_default-ordered] Error 2
Please help me in this regard
M SANTOSH ADITYA
SSSD, ECIL
Phone: 040-27182914, 040-27182977
"I cannot give you the formula for success, but I can give you the formula for failure--which is - Try to please everybody".
- Herbert Bayard Swope
::DISCLAIMER::
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: RE: Problem installing CA for QT manta santosh aditya santosh_aditya
Prev: RE: undefined symbol:MAXvSetup Mark Rivers
Next: RE: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem installing CA for QT manta santosh aditya santosh_aditya
Next: Re: RE: Problem installing CA for QT manta santosh aditya santosh_aditya
