1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor model 3 support for OMS MAXv-8000?
To: "Fong, Nia W." <[email protected]>
Date: Thu, 10 May 2012 11:19:09 +0200
Hi Nia,
yes, I will send you all I have in a separate mail.
Jens
> Hi Jens,  Do you have a model 3 driver for the OMS MAXv that we can
> try out at SLAC?
> Thanks Mark!
> Nia
> From: Mark Rivers [[email protected]]
> Sent: Tuesday, May 08, 2012 12:42 PM
> To: Fong, Nia W.; '[email protected]'; [email protected]
> Hi Nia,
> The current EPICS driver version is model 1, not model 2.
> Jens Eden told me in Nov. 2010 that he had a model 3 driver for the
> MAX family working.
> This is from his message:
> Yes, I have a (beta) asyn driver version for the MAX family (MAXv
> and MAXnet so far),
> which I recently sent to Austen and Ron. I didn't announce it on
> tech-talk, since I didn't
> had a chance to do some testing yet, but if anyone is interested,
> tell me and I will send you
> what I have.
> Using Mark Rivers ' asynMotorDriver base C++ class is very straight
> forward and has
> several advantages.
> - os-independent (we use it with RTEMS)
> - easy to have derived classes for the other MAX-family members
> (they all use the same command set)
>    (writing a MAXp Linux driver using Michael's devLib2 is on my list)
> - the asynOctet layer which Dirk requested comes for free
>     (use a stringout or waveform to send ASCII commands to the Controller)
> With this driver version you may use the auxiliary encoders or use
> encoders independent from their
> motor axis (which is actually the reason why I wrote this, because
> we want to use 2 encoders for
> a single axis).
> If this functionality is too specific, I could possibly remove it
> and put it into a ptb-specific derived class.
> I didn't care for OMS58 yet.
> If Jens is willing I could take this driver and add the new
> coordinated motion API to it, and put into the standard EPICS motor
> distribution.  Tim Mooney has already done EPICS support for coordinated
> motion, but it is an SNL program (like the old XPS trajectory
> scanning), not using the Model 3 API.  So I would just port his code
> to the model 3 driver.
> I was actually talking to Pro-Dex about this today, because they
> have developed a product that is a 10-axis MAXNet controller that
> plugs into the left-hand slot of an ACS Step-Pak.  This allows
> Step-Pak systems to be VME-independent, and with a new driver they
> could also do coordinated motion.  With the new Step-Paks they can
> also drive servo motors.
> Mark
> -----Original Message-----
> From: [email protected] [
mailto:[email protected]
> ] On Behalf Of Fong, Nia W.
> Sent: Tuesday, May 08, 2012 1:29 PM
> To: [email protected]
> Subject: Motor model 3 support for OMS MAXv-8000?
> Hi,
> Has anyone written a model 3 based motor driver for the OMS MAXv
> VME-based board?
> We just ordered a MAXv-8000 Motion Controller VME board.
> Is the current driver in the motor-R6-7 model 2?
> Thanks in advance,
> Nia
Eclipse for EPICS development Zhou, Jingchen
RE: Motor model 3 support for OMS MAXv-8000? Fong, Nia W.
Prev: Re: seq-2.1.6 build problem on Linux Benjamin Franksen
Next: Eclipse for EPICS development Zhou, Jingchen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Motor model 3 support for OMS MAXv-8000? Fong, Nia W.
