1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [CA][waveform] how to NELM?
Date: Fri, 11 May 2012 18:07:17 +0400
Thanks, Mark! It works if I am reading just one PV. But when I am reading 2 PVs - (waveform and NELM), my NELM value is enormously big!!!
How can I read several PVs?
This is my code:
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "cadef.h"
int main(int argc,char **argv)
    int data;         /* NELM */
    chid mychid;
    chid chan;        /* WAVEFORM - file*/
    int status;
    unsigned elementCount, nBytes, i;
    struct dbr_time_char * pTD;
    const dbr_char_t * pValue;
    SEVCHK(ca_context_create(ca_disable_preemptive_callback),"ca_context_create");
    SEVCHK(ca_create_channel("file.NORD",NULL,NULL,10,&mychid),"ca_create_channel failure");
    SEVCHK(ca_pend_io(1.0),"ca_pend_io failure");
    SEVCHK(ca_get(DBR_INT,mychid,(void *)&data),"ca_get failure");
    printf("file.NORD: %d\n",data);
    ca_clear_channel ( mychid );
    ca_task_exit ();
    status = ca_create_channel ( argv[1], 0, 0, 0, & chan );
    ca_search(argv[1], &chan);
    SEVCHK ( status, "ca_create_channel()" );
    status = ca_pend_io ( 1.0 );
    if ( status != ECA_NORMAL ) {
        fprintf ( stderr, "\"%s\" not found.\n", argv[1] );
        return -1;
    elementCount = ca_element_count ( chan );
    nBytes = dbr_size_n ( DBR_TIME_CHAR, elementCount );
    pTD = ( struct dbr_time_char * ) malloc ( nBytes );
    if ( ! pTD ) {
        fprintf ( stderr, "insufficient memory to complete request\n" );
        return -1;
    status = ca_array_get (DBR_TIME_CHAR, elementCount, chan, pTD );
    SEVCHK ( status, "ca_array_get()" );
        fprintf ( stderr, "\"%s\" didnt return a value.\n", argv[1] );
        return -1;
    pValue = & pTD->value;
    for ( i = 0; i < 10; i++ )    printf("%d ", pValue[i]);
    printf("\nTotal size: %d\n", elementCount);
    printf("Timestamp: %d\n", pTD->stamp.nsec);
    ca_clear_channel ( chan );
    free ( pTD );
    return(0);
On Fri, May 11, 2012 at 3:42 PM, Mark Rivers <[email protected]> wrote:
You can just do a ca_get of record.NELM.
From: [email protected] [[email protected]] on behalf of Pavel Masloff [[email protected]]
Sent: Friday, May 11, 2012 6:39 AM
To: EPICS Tech Talk
Subject: [CA][waveform] how to NELM?
I am writing a simple CA client in C.
The client reads the waveform record. And I need to know how many elements there are in it (NELM field).
There is a function entitled ca_element_count() which happens to read the NORD field.
Does anybody know how can I get the NELM field ?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
RE: [CA][waveform] how to NELM? Mark Rivers
[CA][waveform] how to NELM? Pavel Masloff
Prev: RE: [CA][waveform] how to NELM? Mark Rivers
Next: RE: [CA][waveform] how to NELM? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
