Subject: Re: Channel Access monitoring tools
To: <[email protected]>
Date: Mon, 14 May 2012 11:08:10 +0200
On Friday, May 11, 2012, Bill Lavender wrote:
> One of the installations I am responsible for is having trouble with
> unexplained PV connection failures.  What I have is a program that needs
> to do things in a serialized fashion.  In other words, for each of
> several PVs, it needs to start a connection to a PV, wait for the
> connection to complete, and then immediately use that PV.
> At present, I am doing something like this:
> 1.  Invoke ca_create_channel() with a connection state change handler.
>     The connection state change handler sets a flag to indicate that
>     the connection has complete.
> 2.  Call ca_pend_io() to make sure the request is sent on its way.
You want to use ca_flush (or was it called ca_flush_io?) for that. AFAIK
ca_pend_io does not send accumulated requests, it just waits for responses
(and other events).
Cheers
Ben
> 3.  I then wait inside a loop periodically calling ca_poll() until
>     my connection flag has been sent.
> 4.  If the loop has been looping for too long, I declare a timeout
>     and call ca_clear_channel() to get rid of the existing unconnected
>     PV andn then call ca_pend_io() to send that request on the way.
>     My code did not originally have this ca_clear_channel() call,
>     but I added it to see if it would help and in the name of
>     preventing memory leaks.  It didn't help.
> 5.  I then go back to step one to create a new channel.
> 6.  If I execute the outer loop from step 1 to step 5 too many times
>     then I give up and tell the user that I have timed out.
> Increasing the timeouts has not helped.  For debugging, ,I have tried
> timeouts as long as 10 seconds and have not seen a change in the
> frequency of connection timeouts.
> At present, the only client platform that I have that has these timeouts
> is Debian 6.0 Linux (Squeeze).  The same hardware running Debian 5.0
> did not have these problems.  The clients are using EPICS Base 3.14.10
> and the IOC is using 3.14.12.1.
> I am assuming that what I need to do here is to monitor the network
> traffic between the Debian 6.0 machine and the IOC and compare it
> to the traffic between a Debian 5.0 machine and the same IOC.  I see
> that there is a Channel Access plugin for Wireshark that I hope will
> be helpful.  Are there other things that I should be trying?
> The Channel Access code is wrapped in some code of my own, so it will
> not look quite the same as raw Channel Access code, but if you want
> to look at it anyway, look at the function mx_epics_pv_connect()
> in this file
>   http://svn.csrri.iit.edu/mx/trunk/modules/epics/mx_epics.c
> Thanks.
> Bill Lavender
> [email protected]
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Channel Access monitoring tools Bill Lavender
Prev: Re: Problem installing CA for QT Hinko Kocevar
Next: cPCI express Urša Rojec
Prev: RE: Channel Access monitoring tools Mark Rivers
Next: Re: Channel Access monitoring tools Bill Lavender
