1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cPCI express
To: Urša Rojec <[email protected]>
Cc: [email protected]
Date: Mon, 14 May 2012 13:41:36 -0400
Ursa,
I can confirm your findings, COTS cPCI or cPCIe hardware is very
limited.  The more popular bus standards are VME, PXI(e), PC-104.
I've heard some rumblings about microTCA but haven't seen any
products.
Not sure what type of hardware you're after.  We've used cPCI
transient digitizers by D-Tacq, (not in EPICS but it has limited EPICS
support). You might look for cPCI carrier boards, then you can use PMC
or IndustryPack I/O boards.
-ps
On Mon, May 14, 2012 at 12:39 PM, Urša Rojec <[email protected]> wrote:
> Hi Michael
> Thanks for the reply. Yes I know that from the software side there are not
> many differences (backwards compatibility and all). I guess that my question
> was not so clear.
> The biggest problem we have is in finding the hardware - simple DAQ boards
> an so on. There are PXIe boards, but to find a cPCIe multipurpose DAQ board
> turned out to be quite the challenge. Even for the CPU there are not so many
> manufacturers (MEN elektronics have cPCIe , than mostly PXIe cpu boards by
> NI, Adlink, geotest). I know that PXIe can be used as a cPCIe (some
> additional synchronization features of PXI are lost), but when looking for
> pure cPCIe the resources seem to be quite limited. So I thought I'd post
> here, If anyone else has had experience with setting up a cPCIe system (from
> hardware point of view).
> Ursa Rojec
> On 05/14/2012 05:38 PM, Michael Davidsaver wrote:
>> Hello Urša,
>> When you speak with software developers you may not hear PCIe explicitly
>> mentioned often.  For software there is (intentionally) little difference
>> between PCI and PCIe.
>> In our server systems we use PMC modules with a PMC-PCIe carrier card.
>>  This presents a transparent bridge.  No software changes were required to
>> accommodate this.
>> Michael Davidsaver
>> NSLSII Controls Group
>> Brookhaven National Lab
>> On 5/14/2012 5:09 AM, Urša Rojec wrote:
>>> Dear all,
>>> I am looking for comments and suggestions on cPCIe. Do you use any cPCIe
>>> modules as part of your contols? Could you tell me the module name,
>>> manufacturer?
>>> I have been looking at tech talk and cPCI express is not mentioned. Is
>>> nobody using it?
>>> Any help would be appreciated.
>>> U
Re: cPCI express Urša Rojec
Re: cPCI express Michael Davidsaver
Prev: Re: Regarding access of Process Variable Hinko Kocevar
Next: Re: Channel Access monitoring tools Bill Lavender
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cPCI express Urša Rojec
Next: Re: cPCI express Urša Rojec
