Subject: ArchiveViewer issue
From: Dilan Madagodahettige Don <[email protected]>
To: [email protected]
Date: Wed, 16 May 2012 10:05:39 -0400
Hi Guys,
I am working for the STAR experiment as the Slow Control.
I have recently encountered an issue with the ArchiveViewer. To me the Daemons are running fine. I can see it on the Engine Web Server that each of the PV info is connected and working fine.
But one time I saw an issue when I tried to see the plots there was an error message as follows,
java.lang.Exception: Couldn't execute the archiver.values request
 org.apache.xmlrpc.XmlRpcException: Cannot open index 'index1'
So I could not plot or even load any of the PVs.
Then what I did was,
/etc/init.d/httpd restart
/etc/init.d/iptables restart
After this I was able to open the ArchiveViewer but I see the PVs ca be accessed up until to the point where I got  the error message (05/14/2012 @ 15.00) but nothing since then.
Can anybody give me a help regarding the issue? Thank you in advance for your kind considerations!!!
Cheers,
Dilan
Post Doctoral Research Fellow
Creighton University,
Brookhaven National Lab,
Building 1006C,
Upton, NY 11973
Mobile :  631-561-1109
Email: [email protected]/ [email protected]
Prev: 回复: RE: Problem in using synApp sunjl
Next: Re: 回复: RE: Problem in using synApp Tim Mooney
Prev: Re: RE: Problem in using synApp 闫芬
Next: Dectris Mythen 1K Diego Omitto
