Subject: Re: 回复: RE: Problem in using synApp
To: sunjl <[email protected]>
Date: Wed, 16 May 2012 13:50:35 -0500 (CDT)
Wait a minute.  Are you really running synApps_4_6?  I assumed that was a typo, and that you meant synApps_5_6, because synApps_4_6 is eight years old.  But, Kurt Goetze remembered seeing "Problem!" in a scan display long ago, and sure enough synApps_4_6 has this.
If you really are running synApps_4_6, then I hope you're building with cygwin, because no version of synApps earlier than 5.6 has a version of saveData that runs on Windows.
Did you execute the command
    saveData_Init("saveData.req", "P=xxx:")
in your st.cmd file?
Tim
----- Original Message -----
To: "sunjl" <[email protected]>
Cc: "tech-talk" <[email protected]>
Sent: Wednesday, May 16, 2012 10:09:15 AM
I'm confused.
I'm not able to find the error message "Problem!" in saveData's source code or database.
>From what I see, there are only four possibilities for the xxx:saveData_status PV:
"Inactive", "Active", "Mount err", and "I/O err".  Can you give the name of the PV that says
"Problem!"?  Is it xxx:saveData_status or xxx:saveData_message?
Tim
To: "Mark Rivers" <[email protected]>, "tech-talk" <[email protected]>
Sent: Wednesday, May 16, 2012 8:59:13 AM
Subject: 回复: RE: Problem in using synApp
Yes, I set the path and the 'Problem!' is still there.
孙纪磊 敬启
中国科学院高能物理研究所1号厅201室
北京市918信箱 100049
Sun Jilei
Institute of High Energy Physics, Chinese Academy of Sciences,
Accelerator Center, Room 201, Hall 1,
19B Yuquan Lu, Shijingshan District,
Beijing 100049,
People's Republic of China
Tel.: (+86)-(0)10-88236287
Email: [email protected]
发件人: Mark Rivers
发送时间: 2012-05-16 21:51
收件人: 'sunjl' ; tech-talk
主题: RE: Problem in using synApp
Did you open the saveData window and give it a path to save your scans?
From: [email protected] [mailto:[email protected]] On Behalf Of sunjl
Sent: Wednesday, May 16, 2012 8:31 AM
To: tech-talk
Subject: Problem in using synApp
Hi all,
I have built the synApps_4_6 on my PC successfully, but when start the MEDM file "scan.adl" , the 'SAVE DATA ’ still in 'Problem!' state.
Would you give me some help?
Thanks and Best Regards
孙纪磊 敬启
中国科学院高能物理研究所 1 号厅 201 室
北京市 918 信箱 100049
Sun Jilei
Beijing 100049,
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: Re: Problem in using synApp sunjl
Re: 回复: RE: Problem in using synApp Tim Mooney
Prev: Re: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10) Andrew Johnson
Next: Dectris Mythen 1K Diego Omitto
Prev: Re: 回复: RE: Problem in using synApp Tim Mooney
Next: Re: Re: Problem in using synApp sunjl
