On 05/18/2012 01:39 PM, Andrew Johnson wrote:
Hi Mark,
On 2012-05-18 Mark Rivers wrote:
I think we should stick with building one application per detector. But it
would be nice to be able to isolate the application (which has lots of
module dependencies) from the library (which has few dependencies). It
seems to me that either means 2 separate configure/RELEASE files, or
commenting out the extra module lines when only building the library and
not the application.
You could move the application-specific RELEASE entries into a separate file
that I'll call the APP-RELEASE file, which the RELEASE file includes; then to
build only the library the user would just have to comment out the line
include $(TOP)/configure/APP-RELEASE
from the RELEASE file.
If possible I would recommend that Makefiles should look for defined values of
their dependent modules to control whether to build their different parts into
the application (see the usage of SNCSEQ in the makeBaseApp example template),
but that's not always easy to do so the APP-RELEASE file can also define its
own variable say BUILD_APP=YES to switch on/off building the application part
completely. Then a Makefile could use this technique:
PROD_IOC_YES =<appname>
PROD_IOC = $(PROD_IOC_$(BUILD_APP))
With that,<appname> will only be built when BUILD_APP is YES.
That looks like a really nice solution :)
Cheers,
Ernest
HTH,
- Andrew
- Re: using areaDetector as a support library only Bruce Hill
- RE: using areaDetector as a support library only Mark Rivers
- Re: using areaDetector as a support library only Andrew Johnson
Re: using areaDetector as a support library only Ernest L. Williams Jr.
<2012>
2025
2026
<2012>
2025
2026
