1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: embedded linux target with uClibC and PREEMPT_RT needs caRepeater
To: EPICS Techtalk <[email protected]>
Date: Tue, 22 May 2012 18:07:06 -0700
We are now starting to do a lot of run time testing with our new embedded linux target IOC:
We are calling it:  "linuxRT-x86"
Some Ingredients:
Linux Kernel = 3.2.13-rt22 #1 SMP PREEMPT RT Mon May 21 16:55:55 PDT 2012 i686 GNU/Linux
uClibc
busybox
PREEMPT_RT
Thanks to Till Strauman for this work. :)
Meanwhile, I would like to know of any others out there doing this sort of thing as well?
What are you using?
What has been your experience?
And now a technical EPICS build related question:
I found that I need to have caRepeater available for my target but EPICS BASE does not build it.
How have others done this?
We build our target as a CROSS, so caRepeater only gets built for HOST builds.
Now for vxWorks and RTEMS, they use  "repeater.cpp"  which gets linked in.
What I have done for our embedded linux target is the following, is this acceptable?
Modify,  <BASE>/src/ca/Makefile
And added:
ifeq ($(T_A),linuxRT-x86)
 PROD_DEFAULT += caRepeater catime acctst caConnTest casw caEventRate
endif
Then, I did a build like so,
make CROSS_COMPILER_TARGET_ARCHS=linuxRT-x86
Thanks in advance for your comments and help.
Cheers,
Ernest
RE: embedded linux target with uClibC and PREEMPT_RT needs caRepeater michael.abbott
Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Michael Davidsaver
Re: embedded linux target with uClibC and PREEMPT_RT needs caRepeater Rod Nussbaumer
Prev: Re: EPICS hardware support Ralph Lange
Next: RE: embedded linux target with uClibC and PREEMPT_RT needs caRepeater michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS hardware support david.hickin
