Dirk Zimoch wrote:
> I don't see where you set the baud rate. Use something like
> asynSetOption ("MOXA1", 0, "baud", "9600")
Well, this won't work. It works only if the Moxa maps its serial lines
to local /dev/ttyXXX devices on your PC and you use it like a local
serial line.
With the TCP connection, you may need a different way to set the baud
rate. I don't know how. See the Moxa manual.
Dirk
- Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
- "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
- Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
