Eric Norum wrote:
I'm actually kind of surprised that StreamDevice 2-5 (the latest, right?) even works with ASYN from over five years ago.
With every change in StreamDevice I am very careful not to break
compatibility with earlier versions of asyn and base. You can run the
current StreamDevice version with asyn 4-6 and base 3.14.7 (or even
3.13.9 with some tricks) if you like. Sometimes I wish other people
would spend that effort too.
Dirk
- Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Andrew Johnson
- "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
- RE: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Mark Rivers
- Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Re: medm and Xming on Windows 7 64 bit Pavel Masloff
[NI] PXI 1000 EPICS support ? Pavel Masloff
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
