1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [NI] PXI 1000 EPICS support ?
Date: Fri, 25 May 2012 18:41:40 +0400
Hi Mark,
If I would like to use the embedded Windows processor, should I use the existing Windows XP as the host platform and install EPICS base, ASYN, then somehow manage to write a driver for my AI/AO card, and use it in tandem with ASYN?
Or Linux will be a more suitable system?
The thing is that I have all the drivers installed (including the NI 6070E boards) on my embedded Windows controller, because it was in operation some time ago (using NI LabView), but now it's just doing nothing, awaiting the recycling bin.
I am just new to embedded devices like this.
What would you recommend?
Thanks.
On Fri, May 25, 2012 at 6:22 PM, Mark Rivers <[email protected]> wrote:
Hi Pavel,
Yes, you should be able to do that.
One of the devices I support is the XIA xMAP, which is a PXI digital x-ray spectroscopy card.  It can be run either from an embedded Windows processor like you have, or from a separate PC with a National Instruments PCI to PXI link adapter.
http://cars.uchicago.edu/software/epics/dxp.html
You would need to write the driver for your AI/AO cards, but National Instruments should give you a C/C++ callable library to do that.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Masloff
Sent: Friday, May 25, 2012 9:13 AM
To: EPICS Tech Talk
Subject: [NI] PXI 1000 EPICS support ?
Dear all,
I have found an old NI PXI chassis in our lab with the following configuration:
Chassis: NI PXI 1000
Embedded controller: NI PXI-8106
Cards: NI MIO 6070E (AI/AO modules, 3 pcs)
The embedded controller is running Windows XP Professional National Instruments.
Is there any chance to save the device and run EPICS on it?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
RE: [NI] PXI 1000 EPICS support ? Mark Rivers
[NI] PXI 1000 EPICS support ? Pavel Masloff
Prev: RE: [NI] PXI 1000 EPICS support ? Mark Rivers
Next: RE: [NI] PXI 1000 EPICS support ? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
