Dear all,
I want to implement a application via a costumed class, which inherits
directly from the asynNDArrayDriver. It is similar with simDetector in
the areaDetector, just skips the ADDriver.There is no error during
compiling and running. The parameters (asynOctet, asynInt32,
asynFloat64) can also be read & write using caget & caput. But I can not
get the correct array data of NDArray object using NDStdArrays plugin,
the output are just
1 0 0 0 0 0 ...
2 0 0 0 0 0 ...
No matter how I modify the parameters or the source codes.
Finally, I try to use simDetector directly(the defalut ioc startup
script), but the problem is similar, even using the prebuilt
areaDetector.
How to access the NDArrayData through NDStdArrays plugin? Are other
configurations required?
Best regards
Yingbing
- RE: NDArrayData Access Mark Rivers
Re: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" J. Lewis Muir
<2012>
2025
2026
RE: [NI] PXI 1000 EPICS support ? Mark Rivers
<2012>
2025
2026
