1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: device support for CPCI
To: techtalkForo <[email protected]>
Date: Wed, 30 May 2012 12:49:41 +0100 (BST)
 Hello Zia,
I have succesfully developed a device support for a cPCI card on an industrial PC running windows XP. I have achieved it using AsynPortDriver class, so as M. Heron said, I strongly recommend you to look at Asyn layer documentation and Mark Rivers examples.
Cheers.
Subject: device support for CPCI
To: tech-talk <[email protected]>
Date: Wed, 30 May 2012 07:53:01 +0200 Hi
I am willing to write the device support for cPCI 7432 card for EPICS in an industrial PC running windows XP. I have the API functions, header file and dll. I am confused only about choosing the second field for this line
device(bi,VME_IO,devAiCPCI,"cpci")as using VME_IO will need to define the INP field as #Ca Sb (Only Card and Signal Numbers) whereas in the API I will need three fields i.e. card number, port number and line (signal) number.
This is my first time to write a device support so I need the advice from experienced for answers to this question that...... What should I choose the signal type here in second field of that line and how is it mapped to API functions from INP field.
I tried a lot to search answer to this question but it was my weakness that I could not find or understand from available material on web.
With Best Regards
Julio.
Prev: Re: Problem when caput to waveform record 王林
Next: RE: [StreamDevice] parsing rapid inputs Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: device support for CPCI mark.heron
Next: [StreamDevice] parsing rapid inputs Pavel Masloff
