Subject: Re: calc VAL field not updating from bi VAL field
To: [email protected]
Date: Wed, 30 May 2012 11:11:20 -0500
Hi Lewis,
On 2012-05-30 Allison, Stephanie wrote:
> Could this be a round-off error (long to double)?  Does this CALC work:
> field(CALC, "A>0.5?1:0")
If that works, also try the expression "!!A" which is more efficient than
using ?: anyway.  In general I never assume that a true value is 1, it's
better to check for non-zero, so use "A!=0?1:0" or just "A?1:0".
However I admit I would be very surprised if the integer to double conversion
is not exact for the value 1.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: calc VAL field not updating from bi VAL field J. Lewis Muir
RE: calc VAL field not updating from bi VAL field Allison, Stephanie
Prev: RE: Proposed change in asyn - request for comments Mark Rivers
Next: Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Prev: RE: calc VAL field not updating from bi VAL field Allison, Stephanie
