Subject: Re: calc VAL field not updating from bi VAL field
To: Mark Rivers <[email protected]>, "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Wed, 30 May 2012 16:33:29 -0500
Hi Mark, Lewis,
On 2012-05-30 Mark Rivers wrote:
> I was able to reproduce Lewis' results on exactly the same configuration:
> MVME2100
> vxWorks 5.5.2
> EPICS 3.14.2.2
> BSP: mv2100-asd5 (by Andrew Johnson)
> I was also able to reproduce it on the MVME2700, and Lewis said he already
> reproduced it on the MVME5100.  Since those constitute the vast majority
> of CPUs in use at the APS this is a serious problem.  I just saw his
> message that said it goes away with -O0.  L hope we can get a fixed
> cross-compiler!
Are you cross-compiling Base on a Linux or Solaris host?  Please post the
output from running 'ccppc -v' so I know which compiler you're using.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: calc VAL field not updating from bi VAL field Mark Rivers
Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Re: calc VAL field not updating from bi VAL field Tim Mooney
Prev: RE: calc VAL field not updating from bi VAL field Mark Rivers
Next: RE: calc VAL field not updating from bi VAL field Mark Rivers
