tzk6s:
My version of ibtest does not display 'EDVR', but I think the EDVR
status is irrelevant if IBERR is zero. The response is saying that 25
bytes were delivered to the instrument, but your command string only
contains 20 visible characters, and that seems unusual. Did the
instrument respond as you expect? If the instrument supports some kind
of query commands, have you tried sending a query, and then reading the
response? The '*IDN?' query is a common SCPI query that many instruments
implement, which normally returns a string that describes the make,
model, and feature set of the instrument.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
tzk6s wrote:
Hi, everyone:
I'm trying to connect a GPIB device via LINUX-GPIB.The driver for NI
GPIB card had been setup successfully.When testing with "ibtest" ,I got
the erro:
[root@localhost etc]# ibtest
Do you wish to open a (d)evice or an interface (b)oard?
(you probably want to open a device): d
enter primary gpib address for device you wish to open [0-30]: 3
trying to open pad = 3 on /dev/gpib0 ...
You can:
w(a)it for an event
write (c)ommand bytes to bus (system controller only)
send (d)evice clear (device only)
change remote (e)nable line (system controller only)
(g)o to standby (release ATN line, system contro! ller only)
send (i)nterface clear (system controller only)
ta(k)e control (assert ATN line, system controller only)
get bus (l)ine status (board only)
go to local (m)ode
change end (o)f transmission configuration
(q)uit
(r)ead string
perform (s)erial poll (device only)
change (t)imeout on io operations
request ser(v)ice (board only)
(w)rite data string
: w
enter a string to send to your device: :CHANnel1:CURRent 0.5
sending string: :CHANnel1:CURRent 0.5
gpib status is:
ibsta = 0x8100 < ERR CMPL >
iberr= 0
EDVR 0: OS error
ibcnt = 25
Is there anything I missed?
- errro running "ibtest" tzk6s
Re: [StreamDevice] parsing rapid inputs Dirk Zimoch
Re: Proposed change in asyn - request for comments Eric Norum
<2012>
2025
2026
waveform of STRING memory structure Pavel Masloff
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
