1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [CSS] text edit + Go! button
To: Pavel Masloff <[email protected]>
Date: Wed, 6 Jun 2012 09:36:17 -0400
Assuming a script with PVs loc://value and the_real_pv:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
pvs[0].setValue(PVUtil.getDouble(pvs[1]))
Read the online help for more details of scripts, PVUtil.getDouble etc.
-Kay
To:  Kasemir Kay <[email protected]>
Cc:  "[email protected]" <[email protected]>
What about the second option?
How will the script look like?
On Wed, Jun 6, 2012 at 4:20 PM, Kasemir, Kay
<[email protected]> wrote:
You could
1) Have the text entry widget write to a PV on the IOC that does nothing,
then have the 'Go' button write to another PV's PROC field, that that
other PV could be an AO record
with DOL = first PV, OUT = final PV.
So pushing the button will actually cause the value from the text to be
written to the final PV.
Can have any number of FLNKs to trigger a whole lot of stuff, and this
would work with EDM, CSS BOY, ...
2) Have the text entry field write to a loc://.. local PV, have the button
run a script that reads from the loc://.. PV and writes to the real PV.
This will only work in CSS BOY, but is much simpler and doesn't require
anything special on the IOC.
-Kay
<[email protected]<mailto:[email protected]>>
To: "[email protected]<mailto:[email protected]>"
Subject: [CSS] text edit + Go! button
Is there a way in CSS using whatever, but scripts create a text edit
widget and a Go! button, so you first fill in the PV value (nothing
happens), and once you click on the button it writes the text you typed in
one (or a few) records (PVs)?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [CSS] text edit + Go! button Pavel Masloff
Prev: Re: [CSS] text edit + Go! button Pavel Masloff
Next: Re: mask for bitwise operation in CALC record Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [CSS] text edit + Go! button Pavel Masloff
