Subject: RE: EPICS build on armv6l
To: Florian Feldbauer <[email protected]>, EPICS tech talk <[email protected]>
Date: Tue, 12 Jun 2012 14:40:54 +0000
> would it be possible to build
> EPICS directly on this system instead of building it on a different
> system?
If you are running linux on this system then you should be able to do get a host build of EPICS running with some small additions to the configure/os area of base.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Florian Feldbauer
> Sent: Tuesday, June 12, 2012 1:47 AM
> To: EPICS tech talk
> Subject: EPICS build on armv6l
> Dear all,
> we have bought a Raspberry Pi Computer [1] which has an armv6l
> architecture.
> It is planed to use this inside our control system.
> Currently arm is only supported as target not as host for build.
> Since the Raspberry Pi has a gnu c compiler and all
> the libraries I need (also a x-server), would it be possible to build
> system?
> Best regards,
> Florian
> [1] http://www.raspberrypi.org/
> | Florian Feldbauer                 |
> | Ph.D. student                     |
> | Institut für Experimentalphysik I |
> | Ruhr-Universität Bochum           |
> | Universitätsstr. 150              |
> | D-44780 Bochum                    |
> | Office: NB 2/173                  |
> | Phone:  (+49)234 / 32-23538       |
> | Fax:    (+49)234 / 32-14170       |
> | Web:    http://www.ep1.rub.de     |
EPICS build on armv6l Florian Feldbauer
Prev: EPICS build on armv6l Florian Feldbauer
Next: Re: EPICS build on armv6l Andrew Johnson
